waxiboy
- Jan 24, 2016
I cant feel the full potential of Andromeda in dx80....
Sent from my D5503 using Tapatalk
Can someone suggest a dap that can pair with andromeda on which it can make me super feel the electric guitars/guitars. Below thousand dollars
AK300, great pairing with Jupiter.
Lotoo PAW Gold
QP1R or DP-X1
Thanks! I will try if available also the Ak70, DX80 is too warm..and smooth..but the bass is amazing....
How does the Nova match up to SE535/W30/UE900s? I have a aurisonic forte and I kinda want to switch from the extra bass to a more balanced sound.
After my first write up and listening insistently for almost 2 weeks I think I have changed my opinion about the Nova's. I had two initial major complaints with the Nova's - Fit and Bass.
The fit doesn't bother me as much as it used to now that I have gotten used to them. The edges don't rub me even when I wear them for 4-5 hours straight.
The bass has really come alive. I don't know if because I burned them in (I am not sure that I believe that this makes a difference) or more importantly I found the right tips. I CANNOT believe the difference the tips make on these IEMs. I have tried between 10-15 different tips and the Spinfits and modified Comply tips are the only two that produce bass. I am currently using Comply (non-wax guard) tips that I cut the ends off of to make them shorter to fit better. It took me two tries to get it right but man what a difference it made. The stock rubber tips that came with the set just didn't produce the sound that I liked even though the hole in them were the biggest. The Spinfit tips have a small hole but for whatever reason they sound as good as the Comply tips.
My initial write up was 4.5 stars but after two more weeks of listening to these and comparing them to my other IEMs these really are the best set that I have. I personally would give these 5 stars now that the bass has really come alive (not V shaped but punchy and nice) and the fit I have gotten used to.
