jlemaster1957
Check with Burson first before going with the 5A supercharger for 3XP- I don’t think they recommend doing this and it could void your warranty. Good to check.Hi new owner here, should have a open box 3xp delivered Tuesday from headphones.com to good of a deal to pass up!
Just ordered this beast after selling my secondary system amp which was running my Raal CA-1A, a Kinki Studio Thr-1 can't wait to hear if it can run it as well as the Kinki did, as well as seeing if it'll run my Susvara, but I already have a amp for that, Volot.
I was looking at the superchargers and noticed both 5a and 3a are compatible just curious what the difference would be running it underpowered with the 3a a lower noise floor than the 5a? Thanks and can't wait to hear this beast
I never found the 3A supercharger to be in any way deficient. There are lots of other ways to optimize your 3XP than using the 5A which are Burson approved, like op amp rolling and using the 3XP as a poweramp (running a preamp into it, bypassing the 3XP’s volume stage).
It’s a great amp and it will run Susvaras fine. It’s a great ‘gateway drug’ into the Burson system, and can itself also be used as a pre-amp. In the end I returned mine and upgraded to a 3XGT 2023, which does use the 5A and has lots of upgrade options, ie power modules as well as op amps. But the 3XP is a fine amp and now I wish I’d kept it.
