LoveKnight
- Nov 23, 2011
Ok. After reading a lot of information on the internet and use my dictionary to translate some words now I know what I need to DIY. Thanks!
I've been enjoying the ODAC a ton. It's my first external dac. But are there any comparable DACs that have the same amount of resolution but are maybe a little less bright? Perhaps its that I'm pairing it with the O2/HD600, but there are times it can all get a little too much for me and I'm not really treble sensitive. I've had the O2 and HD600 with my Ipod classic and not noticed this as much... If that hadn't been the case, I'd consider I need a warmer amp, but I've been happy with the O2 in the past.
Anyone?
Tried all of the above except odac on a different pc. Will do that next...thanks.
I had a similar problem with foobar. What are you using?
Foobar+waspi. Does the same thing with DS in foobar also if that's what you're thinking.
Was thinking of hooking up a ODAC to the Audioengine A2 speakers. Does anyone have any experience with these kind of setups?
Well, I put sennheiser hd 800 directly on the ephifany edac.
I see the paradise.
Yes, in my s3 with neutron player I had to down the volune of 7-8 db, this, in teory, not very good, but I am very surprised about the super fantastic quality of sound out of my S3 with syhas kernel.
I am not crazy, please try this with high impedence headphone and share your experience.
Inviato dal mio GT-I9300 con Tapatalk 2
