- Oct 6, 2013
HOT D'YAM!!! This lil' AP001 amp hooked onto my the Sansa Clip+ is crazy nice with my VSonic GR07 BEs.
There was much more static/ background noise hooked up to my Nokia N9 along with some flabby bass bloat but this seems to be completely resolved on a rockboxed Clip+ with EQing the bass down a couple of notches (-3 to be exact) with volume at 0 to 2.
This thing is more transparent sounding to me than the FiiO E17 which i bought and sold twice. LMAO The E17 amp was a BIG meh for me, cuz its internal DAC sound quality was much more impressive than its amp section. In fact the Clip+ has also sounded a bit boring to me with its average soundstaging/ neutral-esque leaning 2D sound presentation, but this lil' AP001 seems to add some excitement to overall sound with improved 3D staging and bass quantity (when EQed down that is). Liking very much what i am hearing so far with this paring.
The straight 3.5mm male to 3.5mm male stock connector that came with the AP001 is kinda crappy. The stock L-shape one from my Cayin C5 seems much better in quality....
AP001 is VERY sensitive to EMI, and thus not suitable for use with smartphones. I was just running a few tests. Plugged in to X5 (HO of course), and fast forwarding through a song or idling - I hear just added background white noise from AP001. Put my Note 4 an inch away from X5 and in addition to background noise get a lot of random EMI pops and clicks. I'm aware this is re-branded design so Brainwavz is not in a control of the respin, but adding a simple EMI shielding inside of the module would easily take care of that. Plus, a few caps to filter internal power supply feed will take care of background noise
Other than that, I'm really digging this little guy!!! An excellent sound booster with a permanent extra bass boost. The bass boost is actually well controlled without spilling into lower mids, adds a bit of warmth to overly bright IEMs. What I found surprising, testing it with Altone200 it not just improved bass to my liking (I always crave for more bass!!!), but also tighten up upper mids and leveled it off in comparison to low end. From my experience, I found Altone200 to be too bright for my ears (upper mids/lower treble were piercing my eardrums) so I had to play around with a volume to lower it down to a comfortable level. Doing that brings more bass upfront and makes mids perception to be recessed. So, I had to constantly play around with a volume level to find that sweet spot. With AP001 added in the chain, I can raise the volume up and maintain a great balance between bass and tolerable level of upper mids/treble. Really enjoying that!!! And as others pointed out, AP001 is more suitable for brighter IEMs rather than darker ones. It doesn't pair up well with S0.
