Paul,
Sorry for the slow response. I was away over the weekend and just now noticing your follow-up question.
Joe is really down on foam when used in direct contact with phones and his latest microphones; due to the amount of time he has had to spend over the years picking the stuff out of headphones and other electronics. It's just one of those things he's learned, unfortunately, years later.
“Foam break-down” is sort of like "Sticky-Shed" syndrome is in the case of audio recording tape stock. Who would have imagined either of these problems "back in the days".
He uses clean plastic bags extensively. His cameras, lenses, guns as well as all things electronics are carefully wrapped when not in use in an effort to keep down on the amount of dust and particulate material "proving Murphy’s Law of Selective Gravitation” from being correct.
One other suggestion I should mention regarding his advice to me on the HP1000, which is likely the case as well regarding similar headsets. In the case of the HP1000s he uses daily, he washes their foam ear pads several times a month in a mild solution of “Dawn for Dishes” and warm water. After rinsing the pads thoroughly he then pats out most of the water (without compressing them too much) and then just lets the pads air dry, usually at least for overnight. He feels the oils / sweat etc. picked up by the foam pads may contribute to their premature break down. Don’t know if he’s right or not. I just do it however, just cause…. I also have several sets of pads as well…
I try to follow his example, heed his advice and consult with him on a host on the mundane things in life; such as Joe’s favorite ink pens or his thoughts regarding new toaster ovens. He’s not just a fountain of knowledge on most things related to electronics; his recipe for “gelato” or even “scrambled eggs with onions and peppers” are winners as well. What continues to amaze me about our great mentor is not just his depth of knowledge about life, but his breadth of knowledge as well. (
Happy listening,
Martin
Originally Posted by pcf /img/forum/go_quote.gif
Hi Martin,
Thanks for the great tips. Does that mean we shouldn't store Grados in boxes with foam? That would rule out the original RS1 box and the wooden boxes they currenty sell at Grado labs.
I will now put all my Grados in zip lock bags and maybe stop using all the wooden boxes.
Thanks again!
Paul
