Sure. Here you go. I have a Pixel 6 (not Pro). Screenshot from Bluetooth settings and the B&W Headphones app.Hello Tk33, can you please confirm me as well that within B&W PI7 android app you can see the apt-x HD codec in the app screen on yourbpixel pro not only in developer's option .
I have 3 different devices that can do aptx-hd (i verified on a older Sony bluetooth neckband) but none of them will connect to PI7 in aptx-hd modd
Thank you very much
Bowers & Wilkins PI7
- Thread starter rsnhakan
AcademicBarzo
Yep. Works with some devices, not others. B&W seemingly disinterested in finding a solution. Very disappointing indeed.Sure. Here you go. I have a Pixel 6 (not Pro). Screenshot from Bluetooth settings and the B&W Headphones app.
In my case (may have behaviour or A&K and Fiio mixed up)
A&K Kann. If to Aptx HD, just connects and disconnects automatically. Can force Apt X and works.
Fiio M7 - connects and disconnects. Can't get it to work.
Sony NWA105 - connects, but only AptX classic.
My B&W PX7s, which are also AptX Adaptive, connect via Aptx HD to all three sources without issue.
joe75
- Aug 19, 2009
Thank You TK33, you rockSure. Here you go. I have a Pixel 6 (not Pro). Screenshot from Bluetooth settings and the B&W Headphones app.
I have ordered the KB9P usb dongle 24 bits/96Hz that has both aptx adaptive and aptx-hd codecs from Ali Express, I hope to get at least aptx-adaptive.
That's my last resort since my Samsung phone only play standard aptx codec.
I have a Xperia X compact (APTX-HD) , FIIO M11 Pro (APTX-HD), they only connect to the Pi7 with standard aptx, FIIO M11 Pro (I forced the connexion via a third party app so it might only be SBC i dont recall).
It s a shame the PI7 never got updated - yeah it 's old story- because they are very comfortable in my ears and sound good.
(Honestly no volume control and having to use the app to switch on/off transparency...that's so wrong...if they fixed those 2 small things that would be good enough for me)
joe75
- Aug 19, 2009
Well, i bought a Xperia phone that has both Aptx-Hd and aptx adaptive contrarySure. Here you go. I have a Pixel 6 (not Pro). Screenshot from Bluetooth settings and the B&W Headphones app.
to my Samsung that has none.
Well aptx_hd still does NOT work with the PI7 with Xperia, but at least aptx-adaptive works this time .
That's really strange behaviour from Bowers&Wilkins
édit : no aptx hd either on Xperia phones with B&w PI7...very strange
Dekimasu
- Sep 6, 2010
I have had these for about 10 days now, and I love the sound, especially when using aptX HD over the BT-W3. Unfortunately, the earphones are also driving me crazy.
A few days ago I experienced something strange during my commute where the connection to my iPhone would drop and return about twice a second. It was like the buds were fighting each other over which one would become the master. In fact, I was able to verify that the iPhone was showing connection to two different PI7s at the same time (see picture). After a very annoying commute where I was unable to get them working properly for over an hour, they appeared to recover that evening after I connected them to a new device.
Since yesterday I have the opposite problem: neither bud wants to send audio to the other. I can get either bud to connect to a device and play audio (iPhone, Mac, iPad, PC, case, BT-W3). I also know the buds are seeing each other, because if I hit play/stop on the non-playing bud, it plays/stops. In addition, if I hear audio on the right bud, I can activate noise canceling by holding down on the left bud. However, neither bud will send audio to the "slave", so I only hear audio out of one bud. Meanwhile the battery continues to drain from both sides if I leave them both in.
Factory reset and device reboots have had no effect so far. I'd rather not give up on these, but I didn't sign up for a single earbud experience....
johnston21
- Oct 25, 2005
Is one the case? The buds should show as 1I have had these for about 10 days now, and I love the sound, especially when using aptX HD over the BT-W3. Unfortunately, the earphones are also driving me crazy.
Dekimasu
- Sep 6, 2010
Thanks for the reply.Is one the case? The buds should show as 1
This is with both out of the case. It doesn't always show up that way, but often does. Since the (i) button is the way to get to the screen where you can disconnect or forget the device, the only way to disconnect the second instance is by turning off Bluetooth completely.
I just tried connecting to the computer again after giving them 12 hours off, and I still have the same issue: sound out of the right bud only, but I can turn audio on and off by using the button on the left bud. If I then put the right bud back in the case by itself and reconnect, perfectly fine sound out of the left bud only. Then I can turn audio on and off by using the button on the right bud, but no sound out of the right bud.
Factory reset and reconnect, back to the exact same pattern with sound out of the right bud only. And exactly the same pattern with the iPhone, although at the moment I only see one instance of the PI7 on the Bluetooth menu....
joe75
- Aug 19, 2009
Any comparison with MTW3?, they seem
to be on par soundwise, while Sennheiser have the better controls, apps and probably batter
life as well
life as well
Dekimasu
- Sep 6, 2010
Unfortunately, the PI7s never started working again. I was able to reproduce the same problem with listings for each piece from my desktop's PC menu. I think it it still clear there's a problem even though the page isn't in English. The bottom "Bowers & Wil" is the second earbud. It sometimes shows up with that cut-off spelling on the iPhone menu too.Is one the case? The buds should show as 1
Since the buds are unusable, I'm taking them back tomorrow (or sending them in for servicing, depending upon what the store says).
JamesAnthony
- May 5, 2015
What phones are people using for these? Considering switching from my iPhone to something else to get the most out of them.
tombrisbane
I’m using an iPhone but connect to these using the creative bt-w3 plugged into the port (ddHifi lightning to usb c, then the Bluetooth dongle). APTX HD makes a massive difference over AAC to my ears.
JamesAnthony
- May 5, 2015
Thanks for the reply. I actually just bought myself the by-w3 to use with my mac and it definitely opens these iems up. How do you find the bulk on the end of your phone in day to day use? Ever worried it will fall out or disconnect in your pocket?I’m using an iPhone but connect to these using the creative bt-w3 plugged into the port (ddHifi lightning to usb c, then the Bluetooth dongle). APTX HD makes a massive difference over AAC to my ears.
johnston21
- Oct 25, 2005
iPhone 12 mini, but mostly with my Sony 507 dap.
The Pi7’s are my only TWS at the moment (gave all others to family). Looking at the Fokus H…
tombrisbane
It’s pretty snug with the little L shaped adapter - adds maybe a cm to the bottom but haven’t really had an issue.
Which adapter you use from lightning to usb?It’s pretty snug with the little L shaped adapter - adds maybe a cm to the bottom but haven’t really had an issue.
Total: 6 (members: 0, guests: 6)
