Blon in ear monitors impressions thread
- Thread starter FastAndClean
voicemaster
- Jan 22, 2008
- Messages
- 1,907
- Reaction score
- 1,795
If it works then why not...I wonder how weird the idea of putting what's essentially flagship or at least near flagship eartips on budget IEM sound to a non audiophile...
Tonymac136
My oddest iem/accesories combo is KZ EDX with TRN T2 cable and Xelastec tips. The tips and cable take the price to over 4x the cost of the IEM, but - tips, cable and iem together came to about £20 and they sound better than any £20 IEM OOTB. Stuff like the BL-01 also needs tip rolling to sound its best.I wonder how weird the idea of putting what's essentially flagship or at least near flagship eartips on budget IEM sound to a non audiophile...
JEHL
Well... As mentioned probably not too long ago I've increased bass extension of the BL-03 by about 70hz form tip rolling and a single aftermaket cable (compared to stock/unmodded). And that's just the benefit I can immediately think of, on top of also no longer being death by treble.My oddest iem/accesories combo is KZ EDX with TRN T2 cable and Xelastec tips. The tips and cable take the price to over 4x the cost of the IEM, but - tips, cable and iem together came to about £20 and they sound better than any £20 IEM OOTB. Stuff like the BL-01 also needs tip rolling to sound its best.
Suffices to say, I probably took a gamble by buying an IEM that is well known for being hard to fit... Yet I mamaged to make it pay off BIG.
LaughMoreDaily
That sounds nice, buy why not tell us what tips and cable you used to give your ears a big payoff?I've increased bass extension of the BL-03 by about 70hz form tip rolling and a single aftermaket cable (compared to stock/unmodded).
JEHL
From 4 pages ago.That sounds nice, buy why not tell us what tips and cable you used to give your ears a big payoff?
Also the cable is a Tripowin Zonie, but the point is that it just isn't awful like the stock cable. Cable could be made out of aluminum for all I care.Unfortunately. These were a gift, and for all I know they are the stock tips of some unknown IEMs. That being said it may be worth paying attention to the overall shape of them as shown here
Notice how it's already at its maximum radius somewhere in the middle unlike something like the Final E-type where it maximum radius is at the bottom.
I've heard also that the aforementioned AZLA Sednaearfits are also great for getting seal with shallow insertion, but I haven't bought them... Yet.
Alternatively if you still have the stock tips around. It's definitely worth trying them while flipped. Slater can explain this one better than me.
https://www.amazon.com/8809456020301-SednaEarfitLight-2-pares/dp/B083XNV359?
These are the Sednaearfit Light. The more flexible variant.
I wonder if anyone else knows about more eartips suited for shallow insertion.
Today I applied Oratory1990 PEQ to my BL-03, but with less bass cut. Highly recommend it, it fixes the mids, makes the sound very balanced while retaining the strengths of the IEM (dynamics, timbre). The bass is more controlled and tighter, while still emphasized
Edit: using PEQ on my Qudelix 5K in DAC mode, great little unit!
JEHL
I thought he claimed the BL-03's tolerances were too high to propose an EQ setting.Today I applied Oratory1990 PEQ to my BL-03, but with less bass cut. Highly recommend it, it fixes the mids, makes the sound very balanced while retaining the strengths of the IEM (dynamics, timbre). The bass is more controlled and tighter, while still emphasized
Well maybe they have a wide variance between units, but in my case it worked well, although as I said I had to keep a bit more bass than what was recommended, so maybe this has to do with the tolerance you describe. Generally I am happy with a Harman level bass.
This is what I used (awesome resource BTW)
https://github.com/jaakkopasanen/Au...s/oratory1990/harman_in-ear_2019v2/BLON BL-03
With wide bore eartips such as SednaEarfits standard and KZs star fliptips BL-03 sounds good enough. With other tips usually i used to PEQ with this from KopiOkaya:
Edit: That being said, yes it depends unit variations. My BL-03 sounds nice with this PEQ.
JEHL
Mine looks something like this
Which i believe is an exaggerated version of tgx78's.
I understand Staco's curve, in line with what I applied, but I don't get yours: to my ears and according to most measurements I have seen, the BL-03 lacks most between 3 and 6kHz and you seem to be reducing it further? Or is it the IEM FR measurement? Sorry I'm lost here
JEHL
No, you're not lost, I seem to like very polite treble apparently. And I still can clearly hear it despite this.I understand Staco's curve, in line with what I applied, but I don't get yours: to my ears and according to most measurements I have seen, the BL-03 lacks most between 3 and 6kHz and you seem to be reducing it further? Or is it the IEM FR measurement? Sorry I'm lost here![]()
It's based on this mainly.
Blonvoyance Oppoty EQ.
mtl171
I just got my BLON BL-01, and wow these are super impressive for the price. I'm normally a self declared treble head who chases neutrality, but these are just so darn fun. The bass felt a bit overwhelming at first with noticeable rolled treble and more shallow mids, though after some ear burn in I find myself grinning from ear to ear when listening to pop. There is no noticeable deficit when listening to pop (aside from maybe some air-ier vocals) and the bassy thump just makes everything sound alive. I did however struggle with getting a good seal due to the short nozzle (ended up using the largest included tips and some careful positioning). I would not recommend these for close listening or classical, but for casual tunes these are a fantastic.
