brianzurf
- Jan 14, 2009
Will these shine with a Dragonfly 1.2
Unfortunately I don't have any other cables to test with. The strange thing is that the entire video is extremely quiet on the BL-01s (without the mic button being pressed) except for the Out of Phase section which is loud.
Any ideas for a fix?
Is this a common problem though with BL-01s? I've plugged them into everything in my house with a 3.5mm socket and they don't work on any of them. I would have expected at least one of them would have a CTIA type socket to accept the Blon's TRRS plug.You need an adapter plug or another cable compatible with your device, looks like you're having a CTIA plug on OMTP socket issue.
n=1 I do have the BL-01 with the mic cable and its been working fine for me on all my devices. TBH I never expected the mic on the cable to cause a difference so I just keep buying them for convenience. Though after reading your experiences, I'm reconsidering for the future.Is this a common problem though with BL-01s? I've plugged them into everything in my house with a 3.5mm socket and they don't work on any of them. I would have expected at least one of them would have a CTIA type socket to accept the Blon's TRRS plug.
Got the BL-03 on the way from Amazon.
Really enjoying my Fiio FH3, Qudelix 5K, 2.5mm cable, Spinfit combo rn, but I've been wanting a single DD so it's time to see what the hype is all about!
If you like Harman curve and are so inclined, try this with your Qudelix:Got the BL-03 on the way from Amazon.
I finally got my Final tips in. To be honest, I felt the original BL-01 tips weren't too bad (at least didnt hurt as much as starlines). Though I find these tips have really helped by bringing out the upper mids/treble, while tightning the bass. Plus theyre quite a bit more comfy. Makes me a lot more curious about trying other tips (xelastecs are next).
By dampers are you referring to those filter things that people place on top of nozzles?Its all part of the game. In order of Sound Quality gains:
1) headphones
2) source
3) tips
4) dampers
5) cables
I would put tips above source actually. Since they can make or break the iem if you dont get a good seal. Thats why it is crucial to get a big tip collection (silicone).Its all part of the game. In order of Sound Quality gains:
1) headphones
2) source
3) tips
4) dampers
5) cables
Cables make the least difference (if any at all depending on the IEM and the cable), so don't ever go too crazy buying cables. There are some great aftermarket cables available for cheap if you ever want to roll cables. DO NOT GET CAUGHT buying $50+ dollar cables. It won't do anything but extract money from your wallet.
I know for a fact I cant tell apart anything above 256kbps AAC even while using my most resolving IEMs (ER4XR) I do agree mastering does make a difference, though I mainly listen to pop music these days so it hardly makes a difference. I also realized that varying services have different loudness specs too which does affect percieved dynamics too (especially when comparing Tidal and Spotify).Haha also nobody mentioned about FLAC vs MP3 (file type and bit rate) in the source quality chain? I know a lot of audiophiles swear by FLAC files only, but my 2 cents is that the mastering and recording is more important than whether it is 320 MP3 or FLAC. U can have a well mastered MP3 sounding better than a poorly recorded FLAC IMHO.
