bhjazz
- Dec 29, 2003
Email dispatched to Hammond. I had a chat with a fellow DIYer who works on old computer displays, and he feels the transformer has failed. More soon.
Mark @ Hammond wrote back, on a Sunday night no less. He said the way I was testing it was completely wrong. Instead, he suggested to test it like this:
Red one lead, Red other lead, should be 573.5V, no load +/-2% with exactly 120V input
Green one lead, Green other lead, should be 7V, no load +/-2% with exactly 120V input
This is all you need to do but you could move one lead to each center tap and the voltage should be half.
The 50V can be check by going from the RED/EL with one lead, VIO to the other lead.
Using this testing, the transformer checks out fine. I'm crossing it off of the list.
What in the heck do you mean by "twisted red wire goes to ground" - where do those wires come from?
You sure none of the wires coming out of the transformer are damaged?
Thanks for asking, Eric. The twisted red wires in that photo go to ground. They come in from the IEC inlet. I should have made them up in green.
None of the wires from the transformer are damaged. Double checked, though.
With no power connected, can you measure resistance between the two red primaries?
Sure.
RED/RED: 233 Ohm
RED/RED-YEL: 119 Ohm
So with that in mind, I dropped the power supply board back into the case and connected it up to the transformer. Before doing so, I reheated most of the solder joints just to be sure.
At power up, I was watching to see if the EZ81 tube heaters were showing signs of life, but saw smoke again from C5. I powered it down and found that cap to be much hotter than the other 2 big caps. It also had a great fragrance!
At this point I'm going to replace all three big caps: C1, C4, C5. I'll probably do C6 as well as it is just too close to C5, both physically and in the schematic. C5 for sure is the problem cap. Jeff Rossel originally sent me three 450V 680uF caps so I'll just replace with the same value. They were Nippon Chemicon. I'm sure they were fine ten years ago when I bought them as many others here used Jeff's kits for this project. Maybe that one cap just dried out after all this time. Serves me right for waiting so long. I'm just glad the cap didn't explode. It's not small.
