LV26
- Feb 18, 2014
The hiss is only audible with source paused and volume cranked way above listening level. With a little NFB it is gone. The HD600's sound better with about a 1/4 turn of NFB. Tightens the bass up and seems to exert a little control over everything else. I am completely blown away by the silence of this amp as it is.
That's a nice looking Bijou you built. What headphones are you using? I like the HD600's and HD580's with mine. DT880 is good. HD650 not so much. DT990's suck with this and every other amp I've ever tried them with, so no surprise there.
What is a best choice for Motor Run Capacitors?
Could you recommend some part numbers, please?
-- Regards, Victor
Look at ebay auction #251157598293.
100 mfd, 5 for $50. They are Temco brand. I have no idea if they are any good, but at $10 a pop they may be worth a shot.
Ebay #111355934421
80 mfd Dayton. These should be good to go as far as construction quality goes. No idea how they sound. $9 each.
A lot of the caps described as run caps have 3 terminals. These are dual start/run caps and are not what you need.
Thank you.
I think Audyn a good choice (and available)
I think WIMA MKP10 available with 47 uF/400VDC... Need check stock.
BTW
What is a difference between Audyn QS and Q4 and Q6?
I compare tech. spec. I think they all provide very close parameters (DF, for example)
