Beyerdynamic Xelento!
Oct 22, 2017 at 7:27 PM Post #573 of 3,049
How straight do you want the cable, how are you going to store it on the move, you just want to roll them into large loops just like the photo's, if you are going to store it just like the third cable as in a pouch, it's not going to do any help, the supplied case is pretty good for storing it, this case comes with the Xelento remote and wireless, whiles the wired version you will get a smaller case like I did, I had to buy this case, whiles you should get it out of the package.
I keep them in big loops similar to the one in your left pic. My stock Shure SE846 cable is stick straight once I run it through my hand once (after being looped in the Shure case for a week). I can confirm being able to straighten the Xelento cable somewhat with a little heat. Counter bend the kink, put it under heat until just before it hurts your hand, remove heat source, keep the counter bend until it cools off. Here is my cable after completing the procedure below the Y split ONLY - see the comparison to above the Y split which has not been done yet:
Heat source was a Likewise Fan Heater, nothing special. You don't really need a lot of heat, and this is not a complete fix as it's still a little wavy.
As others noted in this thread, I too found the best seal to be with the bigger ear tips (XL) where as for other IEMs I typically use medium sized tips. Worth a shot for those that haven't found the right fit.
Oct 24, 2017 at 7:54 AM Post #575 of 3,049
Any more impressions on Xelento? Can they be used for watching movies, with great results?
Very good musicality and large soundstage, I'd totally use them for movies, especially with their rather large and good-impact bearing bass. You get a lot of natural tones for voices and such, so Xelento makes an excellent IEM for movies, although at their price, I'd recommend using them for music as well :darthsmile:
Oct 24, 2017 at 8:26 AM Post #576 of 3,049
Thank you, much appreciated your feedback. Xelento seem to be best in ear dynamic driver for me now from what i am reading, and that includes Vega,IE800s.
Have you heard new ATH-E70?
They are balanced armatures but have a very attractive price.
I am looking for discount code of best price to purchase the Xelento.
Oct 24, 2017 at 2:57 PM Post #577 of 3,049
Well, they are one of the TOTL Dynamic IEMs out there!
I cannot speak abotu Vega at all since I haven't heard it, but compared to ie800, Xelento is much more linear in its response, with less bass and treble emphasis, and a more natural tone. Xelento is like a musical and sweet brother of ie800, both being quite good in their resolution and detail retrieval abilities.
One thing I think should be talked about more is also the technoology, Xelento relies on the Tesla tech of their bigger brothers, so it will have some signature parts similar to it.
Oct 30, 2017 at 2:24 PM Post #578 of 3,049
On the eartip topic. I've ordered the Symbio Mandarin eartips from Csaba in Hungary and I must say that after comparing them with Spinfits and the Original Xelento tips they are superior. The best seal I've had with Xelento thus far (by a mile) and as added bonus improved sound quality especially in resolution and tightness of soundstage. Highly recommended.
Oct 31, 2017 at 2:54 PM Post #581 of 3,049
Can you please remind me what that cable is (left and bottom) in your post? It looks really nicely made - I like the job they did with the thin mmcx connectors.
Oct 31, 2017 at 3:05 PM Post #582 of 3,049
This is not a custom cable, its a replacement cable for Final Audio Lab II, the model number is C081, they have this with angled or straight MMCX or with balanced 2.5mm.
Silver coated high purity OFC.
http://final-audio-design-directshop.com/fs/final/FI-CABA
Probably the best looking cable for the Xelento, easily match the design.
Oct 31, 2017 at 3:09 PM Post #583 of 3,049
Oct 31, 2017 at 3:11 PM Post #584 of 3,049
About USD 240.
