Beyerdynamic Xelento!
Nov 3, 2017 at 5:45 AM Post #586 of 2,934
Nov 3, 2017 at 7:40 AM Post #587 of 2,934
You can get them on his e-bay site. The Wide bore is the recommended size for Xelento.
https://www.ebay.com/itm/SYMBIO-W-Wide-Bore-Silicone-Memory-Foam-Special-Hybrid-Universal-Ear-Tips/122782691934?hash=item1c966b325e:g:G5IAAOSwN6JY~ugP
These tips push out everything the Xelento has to offer imho. You can specify what sizes you want on check-out by leaving a note. If you don't you'll get three pairs in S, M and L size.
Thanks for the information, but how do I know what size if comparing them with sony hybrid tips, or spin fit, as different companies have a slight variation.
Nov 3, 2017 at 12:50 PM Post #590 of 2,934
I used the L Spinfits and L Xelento tips. I figured L would be right. I ordered two L's and one pair of M's just to be sure in my case. The L Symbio's are perfect for me.
I use the sony ss or s and xelento M, spin fit I have the cp100 green color, can't remember the size, i'll have to check that out.
Nov 3, 2017 at 1:45 PM Post #591 of 2,934
Tnx for reply :) I ordered 2 pair in small and one i medium.I have the comply isolation and the spinfits.How do you think the isolation is on the symbios compared to these? :)
Nov 3, 2017 at 4:29 PM Post #593 of 2,934
Nov 3, 2017 at 5:30 PM Post #594 of 2,934
The isolation will be on par with comply's but soundwise the Symbio's are superior as they don't suck out some of the energy.
Good description :) That was my exactly my experience with these tips too.
The only downside I found is they're not quite as comfortable for long-term listening. Still, we must be prepared to suffer a bit for good quality audio... :wink:
Nov 3, 2017 at 6:18 PM Post #597 of 2,934
Not for me. The foam inside the silicone creates a bit too much pressure on the ear canals.
Thats the same for the Sony hybrid isolation tips as well.
Nov 3, 2017 at 6:33 PM Post #599 of 2,934
Same for me, I want to buy them, but i have over 30 different set of buds lying around, during my visit to japan in december i will also get a new pair of Sony EX1000, they also have many tips.
