Taz777
I get a bit of clicking on the left earpiece during insertion - more so with the foam tips, less with the silicone tips. Once inserted, there are no issues.
I might get some driver flex from the initial insertion because I press it into my ear canal but once it's in place it's not an issue at all.
Some of the customer reviews says it doesnt fit well and occasionally drops off, so maybe not that ideal fyi.Not sure if someone has posted this, just want to share a link to get the replacement filter in xelento:
https://m.tb.cn/h.Vg2ZqG2?sm=c4b09c
have a nice day!
I'm wondering if anyone has found any great cable for use with the Xelento. The stock is really a great match sound wise but the ergonomics can be a little unpredictable and it is a bit harsh/unforgiving.
I have the ALO Pure silver litz which really removes all harshness, has perfect ergonomics, but it also crushes the dynamics quite a bit.
I would love something with a smoother, un-fatiguing signature while still keeping the Xelento's dynamics/energy.
SP2000 has enough power and authority to drive the Xelento + pure silver litz satisfactory, but since im transitioning back to the less powerful/authoritative AK240SS, the Xelento/silver litz combo has become a little too sleepy unless i crank up the volume.
Since i've found my ideal endgame portable combination, the AK240SS + Xelento, maybe ill try my hand at creating some cables as a side hobby.
Has anyone upgraded the cable on their Xelentos with noticeably improved results?
For DIY I found this cable to be very good sonically:
https://www.aliexpress.com/item/32811822368.html?spm=a2g0s.9042311.0.0.79104c4dD0eHib
I have the ALO pure silver (not litz) and the linked Aliexpress cable sounds a good bit clearer, tighter and more dynamic with the JVC FD02 I am using it with.
It is however rather stiff and microphonic, due to the teflon insulation, despite being nice and thin.
With my heavier IEMs like the JVC FD02 that is OK, but I never tried with my A&K T8iE.
Comfort is also below the really nice and soft ALO cable.
How about another ALO IEM cable: https://headphonecompany.com/produkt/alo-audio-reference-8-in-ear-kabel/Thanks for the Rec.
I don't know whether to believe in cable burn in or not, but maybe over some more time the compressed sounding bass from silver litz will improve. Wishful thinking maybe.
Btw, for others reading, im probably making it sound worse than it is, the combination still sounds absolutely fantasic, im just reaching for perfection here.
Unleashing my inner instagramer!
From memory, reference 8 sounded great, but it has terrible ergonomics. Its really stiff, like normal wire, not flexible.How about another ALO IEM cable: https://headphonecompany.com/produkt/alo-audio-reference-8-in-ear-kabel/
Crushed dynamics as with the ALO Silver Litz mentioned above is a no-go.
I am asking for this ALO Ref 8 since it can be purchased easily within Germany. I am no fan of Big A, overseas shipments and customs.
This is a very good pairing. The Xelento has a heavy emphasis in the lower register and the more neutral sounding 1A is ideal for it. I wouldn’t recommend a 1Z though because it can be a bit too much for someHas anyone tested the Xelento with the Sony WM1A? I'm interested in some feedback how they pair..
Thanks.
Just out of interest regarding driver flex, are there people who can fully open their mouth wide or move their jaws and still hear no clicky sound (without music playing?).
I'm able to insert them and then not constantly have driver flex but when I yawn or make larger mouth movements, they will always click on the left side
(using the XS tips because all the others don't go deep enough into my extremely tiny ear canals).
Other than that they are absolutely comfortable but my OCD just needs to know whether there is a way I can avoid driver flex all together (even when opening mouth or moving jaws for example)
