Driver flex is a new topic to me. i would appreciate if you explain it a little further since I dont know what driver flew is. does the tesla driver get bent after a period of usage time? just bought the xelento a few days ago and this topic does worry me reallyI'd consider driver flex a potential issue. My pair developed it very badly, to the point of just moving my jaw would trigger the clicking sound. Considering I have about 12 IEMs that I rotate through, the Xelento saw very little play, yet still developed the issue in less the five months. Beyer replaced them under warranty, though I fear the problem could easily return again once they're out of warranty. I haven't really listened to them much after getting the new pair.
Beyerdynamic Xelento!
- Thread starter thatonenoob
MarkF786
Driver flex is movement of a dynamic driver, created by pressure changes when there’s an air-tight seal between your ear and the driver. Most typically, it’s only heard when inserting or removing the IEM, assuming again there’s an air-tight seal. The sound to me is similar to flicking the pull-top on a soda can.
That alone is generally not too much of a concern, but if the driver edges become less rigid, then movement can occur with even less pressure changes. For example, in my Xelento it starting making the clicking sound when moving my jaw, or at times even when just walking, since the slight pressure changes in my ear would cause the drivers to make a clicking sound. It was audible while music was playing, and became very distracting.
Typically manufacturers avoid this problem by providing a small amount of venting in front of the driver, thus stopping the driver from moving with pressure changes. Also, using ear tips that provide less of a seal can also ‘fix’ it (though often with a change in frequency response). As far as I can tell, Beyer still has not added any venting to correct the design flaw, and instead replaces IEMs under warranty when a customer complains. IMHO, they should silently introduce a fix in the product.
Well,you've summed up the issue brilliantly.Even I can understand! I'm not in any hurry,I think I'll wait for Xelento Mk.2. I've no doubt that their sound signature would suit me perfectly,but I do get nervous when things go wrong,especially with recurring issues such as this.Many thanks!Driver flex is movement of a dynamic driver, created by pressure changes when there’s an air-tight seal between your ear and the driver. Most typically, it’s only heard when inserting or removing the IEM, assuming again there’s an air-tight seal. The sound to me is similar to flicking the pull-top on a soda can.
Is it possible to wear them down? im looking for a high end iem like the atlas but with better confort.
Dobrescu George
Reviewer: AudiophileHeaven
Do you need something to wear straight-down?
Does anyone have any experience of Xelento vs Sony XBA Z5? Thanks.
RSC08
- Aug 30, 2016
Xelentos have a ton of bass. Something is seriously wrong with your pair as these are highly V shaped IEMs.Hello, i'm new here. Just recently got my pair of Xelento and they sound kinda bright and seemingly have no bass. I tried to exchange them at the store,but they said it sounds fine. I'm currently driving them of LG G7(Quad Dac). Maybe they need a good amp?
Yes looking for something confortable and easy to remove at the office.
ryanmatic
Try some tip rolling first. The stock tips are kinda unique and don’t always seal well (they don’t work at all for me, so I use a pair of Symbio Peels instead). Like @RSC08 said, once you get the seal right, there’ll be lots of bass.Hello, i'm new here. Just recently got my pair of Xelento and they sound kinda bright and seemingly have no bass. I tried to exchange them at the store,but they said it sounds fine. I'm currently driving them of LG G7(Quad Dac). Maybe they need a good amp?
So it seems like only comply tips work for me. Now there's bass that i can hear.
Try the biggest sizes of the regular tips, the Xelento tips aren't as deeply inserted as others, they sort of lie in the outermost part of the ear canal. Also try to insert them with a twisting movement while inserting.
inkoherence
Hi people,
This might be overkill but, anyone has tried the Xelento with the Beyerdynamic A20 amp? Impressions?
Thanks!
Thanks!
inkoherence
And another question... I've bought a 2.5mm balanced cable (the FiiO LC-2.5B), but the ear guides are very uncomfortable to me.
I've been also checking the **** 2.5mm balanced cables. Are they good?
Thanks!
Thanks!
Total: 16 (members: 0, guests: 16)
