Kammerat Rebekka
Sorry I completely missed this. I’ve heard both but the one I used for a/b’ing the Tygr was the 250 ohm pro versionWhich 990 have you had the chance to listen to - the 250 ohm or 600 ohm version?
Nice!! How did you mod them?Still got mine, use it for conference calls on a near daily basis.
I modded them to have dual entry 3.5mm. Yeah still like em!
I've been swapping pads a bit and settled on the grey beyerdynamic pads. They are just a bit more comfortable as compared to the black velour pads.
This one by CustomCans explains it very well:Nice!! How did you mod them?
Are the pads easy to change and how did it affect the sound for music?Still got mine, use it for conference calls on a near daily basis.
The "cheaper" Beyerdynamic headphones all share the same way to change pads: they have a plastic lip that you need to pull over the housing. Bit like using a shoe spoonAre the pads easy to change and how did it affect the sound for music?
The video was spead up so I missed putting the pads back on the first time I watched it.The "cheaper" Beyerdynamic headphones all share the same way to change pads: they have a plastic lip that you need to pull over the housing. Bit like using a shoe spoon
You can help the plastic lip by heating it up a bit using a blow dryer, once you get the hang of it it is quite easy!
In my linked video he "pops the pad" at 2:40 and assembles them back at 18:18
About the changes in sound: If you get the grey pads for the DT880/DT990 there is no change to the sound. The DT770 pads are firmer and might change the sound (for the worse).
Yes, when I got my new headphones, I had to get used to them first before I can totally appreciate the new sound. However, as someone who already got Beyers like the Amirons and I also had the DT880, I was immediatley blown away by the Tygr! The earpads looks really comfy and gorgeous too and nothing is "gamery" at all and that's exactly the way how I like it because ff those ugly "gaming" craphones! The treble peaks are also really smooth too! I did notice it depends on which source you're using. My desk amp is a Fiio K5 Pro and I also use my Tygr with the PSVita sometimes and none of the source sounds the same.Been mostly a Sennheiser guy for a long time, but wanted to try something different. Mainly I bought these because the reviews about how well they image. So far, I guess I can see how someone would say these imagine well. But as far as I can tell so far, they are nowhere like a good stereo speaker set up. The other thing I noticed, and again it could just be me getting used to their sound, but they were pretty wooly sounding at first in the lower mids and mid bass, but after a few hours of run in they seem to have cleaned up. The lower mids can feel a little thick at times but the bass response is very welcome change from the hd600, 6xx and 58x. I feel like they need a good amount of break in before anyone should make a long term decision on these. Mind got way better after a day or two of limited listening, and have incrementally better over the last week of and hour or so a day of listening. Has anyone else noticed this?
Yes, I have the Tygr 300R and I love it. I had the HD560S and didn't like it one bit. Got rid of it.Anyone that have both these and Sennheiser HD560S? Would love to read a comparison!
