Whether an amplifier sounds transparent or not is irrelevant as is tube distortion.
Beyerdynamic DT770 Pro 250ohm Impressions Thread
- Thread starter Matrixnobu
SunshineReggae
- Feb 4, 2013
Transparency is not the sound, it's the technical specs of the amp. You are saying the technical specs of the amp is irrelevant?
No, I clearly said the sound. If you meant the technical specs, then we're on different pages.
kosq83
- May 27, 2013
@SunshineReagge
It is indeed my personal impression, my truth and my belief. If You don't want to agree with that, just don't. If You think that STX is an end game for DT770 250 than I will not make You to think else. Internet is a place where opinions can be shared. So I did. 'I would be ssurely careful as I hhave Essence ' - mate that is great You have it, but it's not making any point. I have it as well and what? Honestly...
And of course I I am not saying that it makes perfect sense to match D200 with DT770, as the potential of DAC will be certainly wasted, but on the way to better headphones we always have these old ones. That makes sense, right? I never got the D200 with intention to use with the cans I stated earlier, but to get some serious cans, just not everything at once.
Looks like this thread is brought to live again, good, than more opinions than better.
Just in case anyone in the UK is looking for a 240V BH Crack, makes a great match for the DT770 Pro
http://www.head-fi.org/t/743100/bottlehead-crack
Cheers
Cheers
Matrixnobu
- May 3, 2012
Listening to Pink Floyd's new album "Endless River"........
Cheers
What isn't the Crack a "good match" for?
The Crack works best with headphones with higher impedance 150 ohms and over it will still work with lower impedance cans and I ran some ATH W1000X 60ish ohms quiet happily with it though the bass was starting to get slightly loose but still very enjoyable and very nice midrange with them.
PBmaster14
- Mar 29, 2014
Hey guys. I was thinking of grabbing a magni and modi for these headphones. What do you guys think?
Bansaku
The answer will always be yes. For $200 you can't go wrong.
PBmaster14
- Mar 29, 2014
That's what I was thinking. Also I was considering the Vali maybe it would be a little bit warmer. So it should compliment this Headphone.
Bansaku
Do you think the DT 770 Pro are bright? I find with proper amping they are actually on the warm side, without I can definitely see why one may see them as bright. The Vali is great regardless, it really comes down to your choice and budget.
PBmaster14
- Mar 29, 2014
Mine are to the bright side imo. But what amp would you recommend.
iancraig10
- Jan 21, 2005
I use either a Polaris or an Ember if I want a 'fruitier' tube sound. There is a certain amount of 'sound shaping' available on both and the bandwidth adjustment on the Polaris really works to tame the top end.
PBmaster14
- Mar 29, 2014
Oh cool. I'm going to look into those. Thanks for your input.
