Fadious
- Jul 26, 2011
Hello headfi-ers!
I have $400 and i'm planning to buy:
- Beyerdynamic DT 990 32 ohm ($300)
- Ear Force DSS 7.1 Channel Dolby Surround Processor ($70)
- Turtle Beach Audio Advantage Micro II USB Analog & Digital Audio Adapter ($25)
- Digital Audio Toslik Cable ($5)
From Amazon (i can only buy from Amazon)
I want the DT 990 because of its great thumping Bass and great sound stage, and because i want something for music, gaming & movies.
I need the DSS 7.1 for having surround sound for games and movies, and i can't buy a multi channel sound card because i'm using a laptop.
From what i understand the DSS also works as an amplifier of some sort & i'll be using it most of the time.
The Toslik cable and the Micro II USB are because i don't have an optical input in my laptop.
THE QUESTION:
Can i get a 250 ohm DT 990 if i use the amplification on the DSS? and is it better if i do?
Also if you have any remarks and suggestions i would be GRATEFUL ^_^
Thanks
THE QUESTION:
Thanks
