what do the dekoni's do for the 1990's sound? my only real complaint is sub bassGet a amp with more power and dekoni elite velours with the amiron wireless foam disc
You dont need to add a g6 for surround you can use the hesuvi plaugin for apo eq
Beyerdynamic DT 1990 PRO - Beyer's open-back mastering headphone
- Thread starter XERO1
https://drop.com/buy/earpadz-by-dekoni
anyone try the midnights on DT1990? they look comfy but I want first hand because 1990 earpads and tough and crap and need to be for the ****ing torture system of pad changing I don't want them to rip while I force them on with the strength of zues and have to deal with drop support
If you want more sub bass get the dekoni choice suede. But be warned bass can be overwhelming because they also decrease the mid and treble regionwhat do the dekoni's do for the 1990's sound? my only real complaint is sub bass
Dekoni elite velours has the most similar tuning to the stock a and b pads it sits inbetween these two stock pads. I combine them with the amiron wireless foam disc to smooth out the treble and increase the bass
There are also the elite hybrid that adds a big amount of bass but in a more neutral way then the choice suede because they dont touch the mids and treble that much
Cheapest way are the amiron wireless foam discs for 3 bucks they add bass and smooth out the treble peak without sacrifice for my taste
I cant tell much about the foam disc combos with choice suede and hybrids but with the elite velour they are a killer combo i will not use the dt 1990 without them ever again and it seems like @Chastity likes them also with the elite hybrids
supersonic395
- Oct 3, 2015
Anywhere in the UK to order the Dekoni Elite Hybrid pads?
As a 1990 owner for several months now, just wanted to join the fray, say hello, and offer my biggest suggestion for improving the listening experience of this excellent headphone (IMO). I’m a big fan of EQ, and found the treble a little excessive on these as well (although I do like treble). Tried all the major preset EQs, including oratory, autoEQ, sonarworks, etc. and found that the toneboosters morphit EQ to be the best of all, easily. In addition to smoothing everything out and bringing up the mids a smidge, it actually preserved the sparkle that most EQs kill on this HP and added something to the soundstage too, somehow (which i didn’t think EQ could do). The morphit plugin has a free trial so i recommend trying it out! BTW, I use the balanced pads, which morphit has a profile for (no analytical though). Am playing MBA > TB morphit > schiit modi/magni 3+ > DT 1990. Although I’ve never heard a higher end headphone, the EQ’d experience has left me wondering how much better a headphone can sound... and how much, when EQ’d, the 1990s hold up against the best of the best. Maybe I’m being naive, but based on diminishing returns...
Anyway, this journey has been incredibly fun - cheers!
Deffy
So the dekoni elite velour pads arrived! Just started using the for a few hours. Initial thoughts are that they are way more comfortable, though I'm not so sure if I like the sound better than the analytical pads. For lack of a better word, it feels a bit more distant?
Now waiting for the Amiron foam discs. Silly me ordered one thinking it was a pair So twice the delivery costs then I will probably have some questions on how to combine them with the dekoni pads.
Chastity
- Aug 24, 2002
The mount ring needs to be popped off. When putting it back on, give it a small turn til it finds it's placement. (It's keyed)So the dekoni elite velour pads arrived! Just started using the for a few hours. Initial thoughts are that they are way more comfortable, though I'm not so sure if I like the sound better than the analytical pads. For lack of a better word, it feels a bit more distant?
Yes it feels more distant and lower volume because your ear is further away compared to analytical pads just increase your volume by 3 dbSo the dekoni elite velour pads arrived! Just started using the for a few hours. Initial thoughts are that they are way more comfortable, though I'm not so sure if I like the sound better than the analytical pads. For lack of a better word, it feels a bit more distant?
Deffy
Awesome, when they get here I'll try it out. Putting the dekoni pads on was a bit trickier than the a pads.
Yeah I figured that was it for the most part. But i might also have to change my EQ. You have on for yours?
+2 db shelf at 100hz 1Q
+3.5 db peak at 4200hz 1Q
This is my eq for dekoni pads with amiron wireless foam disc
Bass shelf to increase sub bass you can also set it at 75hz if there is enough midbass for your liking
And the 4200hz peak to balance the dip and get more energy in the upper mid region
With just elite velours without the foam disc i used the same eq just with extra
-3.5db at 9000hz Q1
To balance the 8.5k peak
Terriero
@Cevisi said me that when you order one "foam pads" item, the package include a pair of them (same for the rings). But, reading your post, I don't know if is correct. Did you receive only one foam pad in the package?So the dekoni elite velour pads arrived! Just started using the for a few hours. Initial thoughts are that they are way more comfortable, though I'm not so sure if I like the sound better than the analytical pads. For lack of a better word, it feels a bit more distant?
Chastity
- Aug 24, 2002
When you order the Amiron Wireless foams, the price is for 1 pad. In the US, that's $3.50 a pad, so $7 for two. I ordered 4, and cost me $14. And I <3 how they internally refer to UPS Ground shipping as "PIRATE SHIP" on the invoice.@Cevisi said me that when you order one "foam pads" item, the package include a pair of them (same for the rings). But, reading your post, I don't know if is correct. Did you receive only one foam pad in the package?
Damn then i gave terrerio wrong information. I ordered via email conversation and said (two pair)When you order the Amiron Wireless foams, the price is for 1 pad. In the US, that's $3.50 a pad, so $7 for two. I ordered 4, and cost me $14. And I <3 how they internally refer to UPS Ground shipping as "PIRATE SHIP" on the invoice.
By the way there is a new dekoni pad for beyers
Choice hybrid
https://dekoniaudio.com/product/dek...-beyerdynamic-dt-and-akg-k-series-headphones/
Chastity
- Aug 24, 2002
Choice hybrid
Holy Mutha of V-Shape, and +10dB on that treble spike!
megabigeye
My ears are crying blood just thinking about that graph.
Total: 6 (members: 0, guests: 6)
