RockStar2005
I certainly shall. I tried them on when I got home from work, but, was hungry so made dinner and chilling out right now. Will start using them tomorrow. Anyway, my first impression is very good, however, you are correct, they cost too much. They are very thick and soft, so, I am guessing they will do a better job of isolation. If not, at least they are more comfortable. And look really nice too.
Oh, BTW, I had to install them differently than the stock pads. Instead of finding the notch and sort of screwing them on, I took the braces off, put the pads on the braces, then snapped them in place. Worked really well. The real sheepskin on the pads is softer and more pliable.
I just reread the Dekoni pads description, and I realize now the velour is not actually just internal but it's actually the part that touches your face too, while the sheepskin is just on the diameter of the pads. I thought it was just in the "donut hole" (inner diameter) of the pads, but it's more than that. So your observations will be helpful for sure as this is quite unusual IMO! lol
