G_T_J
Yes I do.Do you have a multimeter? Use the continuity test to check on the negative connectors
I was going to identify correct wiring polarity by checking continuity between the jack and the other end.
My question is what do you mean with GND can be tied in the headphones. Could the headphones socket (that the 6-pin plug connects) be using a bracket inside to bridge GND pins?
