- Oct 12, 2014
...The DT family of drivers are a literal drop in replacement though (I took the COP driver and baffle assembly and dropped it into a DT770 shell), and I belive if you have a Tesla assembly it also fits.
The Telsa assembly does fit, but it's a pain since they are "angled" and the "tabs" also don't match up on both sides since there is a distinctive left and right driver. In order to get them to fit you have to either remove or bend this one piece that stems off of the high point of the angled driver, and you either have to remove the tabs from the driver or carve the body of the COP to fit them. To illustrate what I am trying to say, here's and image with the "tab" marked marked as green, the "angled" part in red, and that part that stems of of the angled part in blue.
Here's a photo of what needs to be done to the COP housing to fit the T1 (I used your photo btw):
