Beyerdynamic Amiron Wireless
Mar 26, 2021 at 9:26 AM Post #631 of 785
I recently acquired an Impacto (which also works with my Denon D9200, and should work with several Sony and Focal models as well). It does sound very good, and the Universal variant works with Macs, PCs and iOS, allowing me to use the D9200 with Qobuz streaming services running on my iPhone... same would apply for T1/T5 or Amiron Home, while the Amiron Wireless of course works without additional tools.
At the price of 60€ the Impacto is a very good deal I think, good build quality, good USB cable selection (they are even soft and pliable), lightweight and compact. And yes, its intended to hand in front of you, not lay down on a table farther away.
Too bad that Impacto is not compatible with Amiron Wireless.
Mar 26, 2021 at 12:00 PM Post #632 of 785
I'm 99% sure EQ only works when connected to app. It goes away when connected to a device with no MYI app.
Hope you like 'em!
Thanks - i just found it explained on the german website:
"Take a two-minute listening test within the app and save your sound profile directly to the headphones. So you can enjoy your music with perfectly tuned sound - from any Bluetooth® player."
and in the Beyerdynamics MIY Video - The settings are independent of the source :-) So i can easy connect it to the TV and watch movies as well.
For PC connection, i ordered the Avantree DG80 - hope its a good choice.
Lets see how they compare to my Focal Clear and modded Takstar HF580.
Mar 26, 2021 at 12:47 PM Post #633 of 785
The settings are independent of the source :) So i can easy connect it to the TV and watch movies as well.
I'm confused on this part - are settings saved to the headphone or not? I don't recall an option/toggle to save in the app. Will double check later as I'm not near Amiron now.
Looks like a good price for aptx-LL supported device. No aptx-HD though so while you should get good sync for games/videos, you won't get best possible BT sound quality. I find Amiron sounds significantly better on aptx-HD than just aptx.
I use mine with Sony NW-A105 and Fiio M7 daps. Both support -HD codec and the later can act as PC USB DAC and aptx-HD transmitter at once.
Mar 26, 2021 at 4:34 PM Post #634 of 785
I just ordered a pair which will arrive next week and i have a question regarding MYI:
Are the EQ settings stored in the headphone - so they work also when connected to another device? Or does ist just work together with the phone?
Those settings are stored within the headset and can then be used with any Bluetooth source, without any need for the MIY app (which you only need again if you want to make additionalem changes)
From a Beyerdynamic support document:
„The measured values of the SOUND PROFILE are transmitted from the MIY App to Amiron wireless and stored permanently in the headphone*.“
https://support.beyerdynamic.com/hc...alised-SOUND-PROFILE-feature-in-MIY-App-work-
I‘m sure the other EQ features work the same way
Mar 26, 2021 at 7:39 PM Post #635 of 785
from a Beysupport document:
What about wired mode?
Mar 27, 2021 at 1:07 PM Post #636 of 785
The EQ is implemented within the Bluetooth receiver chipset, so this doesn’t apply to wired mode: electronics are not active in this case. Which is a good thing to me, since it means the Amiron can be used without charge... but I don’t use EQ, so I‘d not notice the difference much
May 10, 2021 at 1:26 AM Post #637 of 785
Hi guys...just got this headphone for few days and found it the low are quite thin and the high are harsh....so which Dekoni earpad can fix these issues? because there are too many models and I am confused...thanks
May 10, 2021 at 1:42 AM Post #638 of 785
EQ is your friend, and also much cheaper than new pads!
May 10, 2021 at 4:10 AM Post #639 of 785
Hi, when you want a boost lows a bit, have better fit and not lose overall tonality (character) than V770 pads are fine, but YMMV as always.
May 10, 2021 at 5:25 AM Post #641 of 785
hi may i know what is v770 pad and what is YMMV?
V770 pads are velour pads for Beyerdynamic EDT 770V headphones and YMMV is for Your Mileage May Vary = for me it is fine and for you who knows... :)
May 10, 2021 at 2:38 PM Post #643 of 785
I got it....so any comment or reason why no need Dekoni? just want to know..
I've ordered Brainwavz (don't remember exact models, You can find it in may posts back in this thread) Sound signature has changed a lot with those pads bass was to pronounced and I've feeling that sound-stage and detail revealing was hit on most. I'm no bass head so maybe you will like that kind of sound presentation.
May 12, 2021 at 4:07 AM Post #644 of 785
OK...will take a look on brainwayz....I am no bass head too but i think Amiron Wireless is really too thin in the low part...
by the way does the velour pads for Beyerdynamic EDT 770V very similar to Amiron Wireless original pad?
May 12, 2021 at 5:46 AM Post #645 of 785
Maybe it's because the earpads are not properly placed on your ears which loses the bass. I can confirm about the thin sound in the low part. Once the earpads are placed properly, the sound will be much better. Geekria earpads covers will help too, they also protect them.
