- Nov 11, 2004
just to make sure I wasn't fooling myself, I just played Jarrett's Koln 24/96 second segment with wifi and BT on and then off individually. Each time I turned a radio off the background became quieter or more black, piano notes had more body, and his grunt or ramblings more clear and almost intelligible. All this at about 76db through my speakers because my boy is not feeling well and I cannot turn it up. Next came Andreas Vollenweider's White Winds CD with Glass House. the decay on the flute was much longer, wind movement was easier to pick out and even the glass chimes were less crunchy. Space was more apparent in the mix and dynamics a little bit better. And this was with the async, timing correcting Halide Bridge feeding my dac.
If it were the Silflex Toslink, I doubt I could hear the changes as easily, but I have in the past. WMMV and all that since my "audible changes" are another's "can't tell the difference".
EDIT: Could it be that what I and others are hearing is power supply related or processes related and not RF related? Just a thought. I do know that isolating the switching wall wart for my external hard drive with another power conditioner helped the sound as a reviewer of PM had suggested. I know it is hard to believe it could but it did. Also similar to the early discovery that an external hard drive sounded better with itunes than using an internal hard drive.
