intlsubband
Thanks for that. I'm surprised that it's so hard to find a high quality RCA matrix box available. You'd think there would be a decent market for that, for a reasonable price.
Serious question - it seems like my post about my contact with Schiit was ignored.
Schiit customer service said that splitting the signal off a DAC with simple, cheap splitter cables was fine and would not affect the signal.
Yet everyone seems to be posting about $1000 splitter boxes.
Why? What am I missing here? Do you guys not trust Schiit or is there some other reason?
Nothing against Schiit - but as far as I understand, an analog signal split into 2 will unavoidably lose some of its power.
Also, I'm looking for a 2X4 solution at least (a 2 source, 4 output grid) - so a Y splitter is also not relevant for me for those reasons.
A splitter box (whether a 20$ or a 1000$ one) will be electrified and should keep all the signals at their original strength.
If you split a DAC signal to two amps but only one of the two amps is ON at any gievn time, would you still have the impedance / 3dB reduction mentioned?This has already been explained.
Provided that both input impedances are sufficiently high and more or less equal if you split a signal into two there will be no loss of signal quality but the strength will be halved. Resulting in a 3dB loss. So if you keep on doing it eventually it's going to effect your S/N ratio. The convention is you can safely split up to 3 times provided you have sufficient gain available. Which you probably have. Extra cable length may also lead to noise if you have a ground issue.
Unbalanced line level splitters (and combiners) are rare. You can see the problem. Connecting together the grounds on several consumer grade appliances spread over a wide area is almost certain to lead to ground loop issues. That is why professionals use something called a distribution amplifier for this task. It not only splits (or combines) a signal it also converts unbalanced to balanced and provide a small amp per channel to adjust the gain. You can get cheap ones from the likes of Berhinger and ART or top of the range from Drawmer and Radial.
http://www.behringer.com/EN/Products/MX882.aspx
http://www.drawmer.com/products/signal-distribution/da6.php
I still think that if the OP has the cash he would do best with a basic audio interface which is designed for the task in hand. And many other useful functions. You can get a 2 in 2 out unit with headphone from around $150. better would be 2 in and 4 out which starts at ~$200. If that's too steep then stick with a simple Y lead for now and hope you don't get a ground loop.
