TooPoorForHiFi
Previously known as MidNighTempest
Nice HCK Bro would fit the bill for your genres.
Others will have some good suggestions too.
Thanks! Do you happen to know what Comply Foam model would fit them?
E-MI CI880 is the same as Estron/Timmkoo C630. The upgrade version is C631 (E-MI CI980). 2BA+DD. You can find it here as JoyPlus JP1: https://www.amazon.com/balanced-armature-microphone-headphones-compatible/dp/B073F866FK
ES660 (C660) has the same drivers as C630, but looks different. E-MI doesn't sell it.
Sub 100.00 or any price point?Can you guys recommend your Top 3 or so IEM with MMCX connection? Music: Hip-Hop, R&B, RAP, mainly modern stuff.
I love the Tennmak Piano for around 20-25.00 bucks, especially for bass heavy music. It has quality subbass for daayyysss, lol.Under $50.
Therefore, if all EMI did was add a 2nd identical BA in the nozzle (with no other changes), that doesn't exactly sound like an upgrade (unless the CI-880 didn't have enough treble for you).
And I understand that the shell is different and therefore could have different tuning via the shell.
Also, the Magaosi K3pro sounds very good with those genres.
One of my favorites that is highly tip dependent is the tennmak crazy cello. With the right tip and seal, they sound darn amazing with any genres, and really pump out quality bass if it's in the recording.
Couple of thoughts
Doubling up the driver doesn't have to mean it produces additional volume or power in the treble. Depending on wiring it may be that each driver is driven 1/2 as hard to avoid the distortion that comes with pushing a single driver past its limits.
this could result in a more mellow version than the single driver if it was approaching its limit.
Also, different shell would effect a Dynamic or vented BA but a sealed unit BA should be immune to shell changes. Changing the length or diameter of the sound bore would have an impact, but the shell should be a non-factor.
Guys, can you help me with eartips? How do different eartips change sound? I have long narrow ones, they tend to lower bass, And short but wide ones, they are good, but rly too short, not comfortable. Foams.. Donno, not a fan.
I used the word "upgrade" mostly in evolutional meaning. C631 was the Estron's flagship not long ago. Compared to C630 it's more expensive, has bigger DD, more BA drivers, better cable, and slightly different tuning. It's a strange thing, but I can't find any customers feedback on Amazon anymore. There were a lot of them several months ago. And the only full review in Japanese language (http://blog.livedoor.jp/rev_/archives/20802731.html) is also removed. As far as I remember the author said that C631 has more detailed sound with better mids. So the only available feedback now is located here in the Chinese / Asian Brand Info Thread: https://www.head-fi.org/threads/chi...phones-and-iems.820747/page-666#post-13594473When you say this is an "upgrade", would you mind clarifying that statement?
Assuming it's correct in that it has the same drivers as the CI-880, the it appears that they all they did was simply add an extra BA. Well, the treble of the CI-880 is awfully hot for a lot of people. The Amazon review isn't exactly glowing, and backs up my fears about the treble.
I personally love the tuning of the CI-880, but it is just about at the limits of my treble tolerance. I personally wouldn't want any more.
I'm going to wait for another HeadFier to try it out first before I decide what do to. If it is a true upgrade to the CI-880, I'm all for it because CI-880 a great IEM!
For Urbanfun, for the OP, make sure you get the Hybrid one, though. It's the model I love.i like them both--the hlsx is warmer and has a richer tonality and the uf is perhaps more revealing/lifelike
And maybe MidnighTempest might be interested:I'm looking for a nice iem with detailed vocals and nice deep bass.
