Hi Guys. I promise I did a search first!
I'm looking for recommendations for a high isolation chifi IEM for use onstage. Standing next to percussionists on loud stages and wanting to preserve some remaining hearing.
I'm a trumpet player/singer, so I don't need lots of bass or really
any sub bass. So I'm looking for a flat response.
Budget is about $60/£50 but would pay more (or less!) for the right product. If it's good hifi quality for personal use that would be nice too. Again, I listen to jazz and some acoustic/vocal/folk/indie so I'm not looking for big bass.
I've found hiSenior B5+. Sound profile seems good and price is OK... but
this review says it's isolation is only 'average'. Is that right?
I have some Rock Zircons, which I like the sound of (don't need quite so much bass, though) but the isolation is not enough.
I do like a bargain, too!
Any thoughts?
My go to IEM for stage monitoring is the Audiosense T800 (30+ dB isolation), but that's out of your price range as it is $298 USD. Some Etymotics are supposedly quite flat and have good isolation, though I haven't tried any and they may be out of your budget too. And they require quite deep insertion and look uncomfortable (maybe ask the rest who have tried it).
A few other options I have tried for stage monitoring in the past, and are sub $100 are:
1)
Hisenior B5+: Around 80ish USD during sales. Unvented 5 Knowles BA. It has about 15 - 20 dB isolation if u can get a good fit. It is N shaped (midcentric), with rolled off subbass/higher treble. It is hence not "flat response" as you require, as the mids especially lower mids are boosted and coloured. This makes it excellent for vocals, especially male vocals, so if you are a singer you will have a field day. Timbre and technicalities are excellent. It takes well to EQ so if u need to EQ while doing stage monitoring it takes EQ like a champ. I occasionally get a bit of ear discomfort with this for longer usage due to the B5+'s concha protrusion (YMMV as we have different ear anatomies, but I can counter this by using a longer nozzle eartip so as to lift the shell and concha protrusion away from my ear). The other issue is that the B5+'s soundstage is not the widest, but the imaging and instrument positioning are spot on, so it still is a good stage monitoring IEM in my opinion.
It is a great set for vocals, classical, jazz and indie/acoustic stuff if u listen to these on the side, but due to the lack of bass, maybe not so versatile for other music genres.
2)
DUNU DM-480: Around 70ish USD. Dual dynamic driver, unvented. About 25 dB isolation. U shaped, wide soundstage. The bass is linear, so there is no obvious bass bump, but the subbass extends very low. It is not that prominent on the midbass, but the subbass gives a nice visceral rumble that is felt rather than heard. There's a slight treble roll off, but it captures the entire frequency response not too badly as such. The mids are a bit recessed, but not overly. Techincals are excellent for a pure DD set up, but the mids/treble timbre is not the best for a DD setup, so trumpets/vocals may occasionally sound a bit artificial. Very comfortable.
3)
KZ ZS10 Pro: Around 30ish USD. 4BA + 1DD. About 15 dB isolation. V shaped, so maybe not the best for stage monitoring, but if u can EQ the mids up, it is not too bad in technicalities. It has a midbass bump so it is a bit on the bassier side and timbre is not the best, it has the famous KZ "steely timbre". But half of my bandmates use it due to the cheap price and good technicals. Very comfortable.
4)
Jade Audio EA3: Around 40ish USD. 1 DD + 1 BA. About 20 dB isolation. U shaped, wide soundstage. Technicals not bad, but it is a bright IEM, so if you are treble sensitive, not the best option. Vocal timbre is a bit dry and thin, but not too bad for instruments. Also a linear bass with good subbass extension. Very comfortable.
If you don't mind using headphones, you can consider the
Audiotechnica M40X, it is truly quite flat in the FR and is closed back, so isolation is not too bad. Technicals are above average. It is boring for normal music listening due to the flat FR, and some may not like using cans on stage as it looks like Princess Leia from Starwars LOL.
All the best for your search!
