lxlx,
As a side note, IF you get the Z3, I recommend you review the copied & pasted document below that I created which lists the best camera settings for that phone. You would need to switch to Manual Mode as Superior Auto Mode (SAM) on that phone is really good but not as great as what Manual mode can achieve.
Cheers!
Sony Xperia Z3 (Manual Mode) Camera Settings
Resolution: 15.5 MP (or 20.7 for 4:3)
Focus mode: Face detection
ISO: Auto
Metering: Face
Nighttime Flash: Red Eye (Tell people before you take the shot that it will flash twice. DON'T say anything else besides "TWO flashes" while showing your 2 front fingers as you say it. Or "It'll flash twice." Anything else will lose their attention. lol) Or, if Red Eye still produces pics with "red eye", switch to Auto immediately. (IF flash just isn't working, day or night, just turn it off.)
Daytime Flash: Whether people are involved or not, enable “Fill Flash”. It’s a lighter version of Flash. (Why Fill Flash? Compare these 2 pics….. 1)
Without Fill 2)
With Fill
EV (Exposure Value): -1 (you can adjust b/t 0 and -2 if you’d like) Higher makes the surrounding lighting brighter, lower makes the surrounding light darker.
WB (White Balance): Auto
(except under natural ((day)) light, then use sunny or cloudy option/icon depending on current conditions)
Important Note: You can make Manual Mode (MM) your default setting by simply ALWAYS using the stock camera app to start the camera up, NOT the dedicated camera button on the side of phone. The dedicated camera button will always bring up Auto Mode, which you don't want. Just make sure you use the camera app to first go into Manual Mode, apply my settings above (which will save them for next time), then exit out. The next time you tap on the camera app, it will take you to where you left off............ in Manual Mode.
[COLOR=404040]More non-people pics: For nighttime outdoor pics with little to no light: Switch to 8 MPs in MM, and select “High (ISO) Sensitivity” under Scenes,
no flash. (Night Scene mode for light trails: Be warned it uses a very slow shutter so you'll need to hold steady by resting your shoulders against your body or supporting the camera against something. It uses low ISO and slow shutter to produce very high quality photos with an artistic flair. Try it out on a busy street at night.) [/COLOR]
