according to gsmarena
HTC Desire EYE has a superb audio quality, read that just before pulling trigger on Axon and since Eye is on a sale now I can get it for 199$
not that I will buy it only according to gsmarena, so any experience anyone?
thanx !
posting on behalf of
@thepooh
"As far as audio is concerned, the Desire Eye is quite decent with better performance than previous flagships running Beats Audio.
You will like the 3D wide soundstage with high enough volume levels , but it sounds good only with mp3 through the stock player.
1st issue : I tried flac and it catched a lot of hiss, sibilances and harshness (with all my headhones), as if it was forcing the hardware to support lossless files.
2nd issue : overheating, I suppose that it has been corrected through FW updates.
3rd issue : tricky 4G and death grip wifi, even in full coverage 4G will work but once you restart the phone, it won't work anymore.
4th issue : the white version gets dirty very easily and not cleaning friendly
5th issue : some uneven lightning on the screen, the lower part seems to turn darler with a yellow tint, I saw this on 2 blue units but the red/white seems to have a better screen
Honestly, now that we are in 2016, the Desire Eye is considered as a mid range in terms of technology and entry level in terms of audio capabilities. You have better options out there (M8 should be available less than $300, A9 as the perfect alternative for a few bucks more"
hope this will be to someone as helpful as it was to me !
