Best Smartphone for audiophile Part II (Updated: Mar 2019)
Discussion in 'Portable Source Gear' started by artpiggo, Jun 19, 2017.
Tags:
133 134 135 136 137 138 139 140 141 142
144 145 146 147 148 149 150 151 152 153
  1. artpiggo
    Nex S has 2 models. One is china rom. Another is global rom. China rom update (20 updates) is more frequent than global rom (5 updates). The fingerprint is improved a lot after first time use.
  2. artpiggo
    Great choice. Shanling m0, BTR3
    Adding another choice. ES100 if you wanna try 2.5 balanced output.
  3. civciv
    Keep an eye on upcoming Shanling UP2. BT/DAC without screen. It has ES9218P
    Thearcade12 likes this.
  4. bencherian
    That's good news
  5. Auxillium
    Has anyone tried the new Poweramp update? Seems like it's finally out of beta now.
  6. lxlx
    Intereting, same as M0. I wonder how much smaller it can get. Versatility of M0 is insane. And... hifi wise, do we really trust LDAC that much? :D
    I think I stick to usb c cable...
  7. kutulu32
    Ldac is not trully lossless or do i make a mistake?
  8. artpiggo
    Yes correct but it is in middle between "convenience" and "fairly good quality"
    And also buying shanling m0, you will get both dap and dac function in cheapest method.
  9. Thearcade12
    It's not lossless but right now it's the next best thing to an actual wired connection.
  10. Sound Eq
    well i have iphone xs max and dam love irs sound, i think they have evolved sound wise from iphone 8 alot, makes me why even own a dap now
  11. kutulu32
    How does the sound compare with previous versions of iphone? I have listened until Iphone 6 and i can say that iphone 4s and 5s were best in audio . Sound is even better using a cable that bypassed the internal amp and connect an external amp. The downside was that iphone 4 and 4s didnt support hires
  12. Sound Eq
    with iphones up to iphone 8 i felt they are a little bloated with bass, no i hear it more balanced still there is good bass but the mids are more clear
    i mean yes some high end daps sound better than iphone xs max but with iphone xs max the sound is really good and many can enjoy it without the need to buy a very expensive dap to get that extra 5% more of details
    Wes S likes this.
  13. ggeinec
    I haven't tried it but I went to the Poweramp discussion forums and it seems a lot of folks aren't happy and want back the old version. Too early to tell yet if this is just resistance to change or if the new version is a step back.
  14. Broquen
    Purchased ES100 some weeks ago to give it a try by myself and have to eat some words...
    SBH50's bluetooth 3.0 or GGMM A1 are quite insufficient regarding SQ. IMO ES100 clearly plays another league (not to mention balanced mode option and ES brilliant app).
    aptX HD and LDAC (when the streaming is in best SQ mode) should satisfy almost everyone and I'm very happy that the time has arrived. It can only go better.
    On the other hand, IMHO sound is still better out of Redmi Note 5 using 3,5mm jack with no EQ (ES100 would be a "8,5 out of 10" maybe?). Codecs can always improve (I think there're already some news regarding something better than LDAC on the way), and still did not give it a try in balanced mode. This, sir, has been a very pleasant surprise. To improve with a more solid construction and USB C connector, but deserves every cent spent in it :beerchug:
    andrewski likes this.
  15. artpiggo
    Glad you love it. I would say HWA (huawei hires audio codec) is better than LDAC codec (even it is in same bit rate)
    So we need to wait for more bluetooth dac support on HWA. :)
    Broquen likes this.
