Best Smartphone for audiophile Part II (Updated: Jan 2020)
Mar 16, 2024 at 2:37 PM Post #5,161 of 5,189
Maybe it is locally connected?
Here in UK, I jump on the train to central London, and phone was suddenly fighting for connection, on off on off, and suddenly black screen... Even replaced sim card, no help. Phone was even loosing normal connection when shopping... I could not write message... Now I have samsung s24, the same sim card, no issues. If that was connected to sim operater not a phone, that worst as means sony do not provide universal use.
I was driving iems only so no issue with power, and for travel listening it was good enough I have to say, just to kill time.
For camera you need patience with sony, lots of settings, and professional like options, very nice, but for most people too much. And was overheating fast, this was later solved a bit with software update.
That's really mad, to deal with a faulty device and don't get the support from the vendor.
Yes, as an owner (and user) of the Alpha6400, there was no way around. :)
I like to fiddle around with the settings.
Mar 27, 2024 at 8:17 AM Post #5,162 of 5,189
Which LG should i buy, guys ? Only flac 16/44.1 music, no other criteria.
Easy to purchase any secondhand LG from v10 to v60, g6 to g8x in my country.
My headphones are sph9500 32ohms, m40x 35ohms. Low ohms is bad for quad dac ?
Thank you.
Mar 28, 2024 at 10:35 PM Post #5,163 of 5,189
Thank you.
I can't vouch for any of the other LG's but I do think my V30 does a good job of pushing most everything. I've noticed low sensitivity seems to be more difficult for it to push as opposed to high ohms. It'll push my 58x with 150ohms/104dB easily but struggles with my X4's at 25ohms/91dB. The SPH9500 is pretty easy to push though at 32ohms/101dB and the M40X is 35ohms/98dB so you shouldn't have a problem with any of the LG's.
Apr 9, 2024 at 9:16 PM Post #5,164 of 5,189
Thank you.
The quad HD on some of the later models is engaged only when >16 bit files are played on the native music player. I reencoded my music to 24bit without added dither, with makes the files bit identical in FLAC, bit triggers the HD symbol.
However if you use PowerAmp APP or Neutron APP with the right settings you can ignore this.
May 20, 2024 at 7:53 AM Post #5,168 of 5,189
What is the difference between Lg V10 Korean version F600 and the other versions in terms of hardware/SQ?
