Sonic Defender
I retired my G8x as a phone and use it as my dedicated music streamer. It does a fantastic job.
The LG G8x is prolly the last of the true audiophile smartphones. Quad Sabre dac.
What about Lg v60?The LG G8x is prolly the last of the true audiophile smartphones. Quad Sabre dac.
What about Lg v60?
While my moondrop miad01 is on the way to me can ypu please give me an example of full size balanced headphones?
This days i use audiotechnika ath es10 and a2000z headphpnes.
I need better than my.
Thanks
The Monolith M1060 (open back) & M1060C (closed back version) are fine examples of full sized balanced planar magnetic cans. They come with stock SE cables (dual 2.5 to 3.5); however, I bought a dual 2.5 to 4.4 balanced cable to pair with the balanced 4.4 input on my Zen can and they both sound way above their £300 price point - more like £1000 territory.While my moondrop miad01 is on the way to me can ypu please give me an example of full size balanced headphones?
Thanks
I asked about which model have balanced output. It means not 3.5 mm single output, when each channel drives only 1 chord and a ground, but when each channel have they own 2 independent chord ( 4 cables for 2 channels, not 3 channel ( like usual 3.5 mm jack) its 4.4mm jack with 4 separate contacts going inside amp of the 4.4 jack.
I dont know any fullsize headphones with this jack, and i dont like tonuse in ear phones...
.fostex t60 are balanced. I believe it comes with 3.5 to 3.5 and 3.5 to 4.4 cables. I forgot. I bought my own longer 4.4 cable so I could use from hammock. May need a little modding if the bass is not up to your tastes. The tonality to me is bar none. the t60s also need power to shine so you need a powerful amp too even though it is only 50ohms.
Seems that the re-tuned & modded "Argon" version of the Fostex T60RP from Mod House Audio has been all the rage over the past few years.
The hand re-tuning, rebuilding, and various customizations do rack up the cost to $410-$489 or up to $200 more than the stock T60RP but from how Zeos' explains it the extra 50-60% these mods cost elevates the listening experience on the "Argon" to match cans that cost hundreds more:
Honestly this understanding of how good a professionally hand-modded Fostex T60RP is puts the Mod House Argon edition in my personal Top 5 List to add to my collection along with the Sennheiser HD490 PRO (for comfort & video editing), Altiat Cal.1H (timeless CNC-milled design & stellar build quality), and GK UltraPhones (world's best passively-isolated headphones).
Fostex themselves seems to have a re-tuned "50th Anniversary Edition" of the T60RP for $399 (probably $345-$360 on sale):
https://www.fostexinternational.com/docs/products/T60_50th_Anniversary.shtml
I believe each version from both Fostex and Mod House Audio come with a 3.5mm "TRRS" balanced input port so it's just a matter of finding a "Balanced 3.5mm-to-4.4mm balanced" cable or a "balanced 3.5mm-to-XLR" + "4-pin XLR-to-4.4mm balanced" cable combo.
I spent ~$25 on 2 materials and only used 1 material and like 25 cents of putty. my t60s have some thump now but not the punch of t20s. I forgot the name of the website but it is in previous posts but I got refurb t60s that were new for $200 plus whatever shipping and import fees.
Well it seems @korzh is looking for something comparable or better in the same price range as his AudioTechnica ATH A2000z which still goes for $600 new/open-box or at least $350 used.
The Mod House T60RP Argon with the Alcantara headband strap and thickened suede pads lands right in the middle at $479.
Stock T60RP can be had used for $200 and sending them into Mod House f
The biggest downside is the wait time to get one's hands on a T60RP Argon let alone sending-in one stock pair to be modded then sent back: 14 weeks to 16+ weeks
Might as well be a Christmas gift for yourself if you order one by the end of this month
*$10 below the most expensive config with the deerskin headband strap
