So I have the LG V20 and was wondering what smartphone has the same quality with slightly more mid range warmth and thicker vocal? Preferably similar sounstage or wider thanks.
Is Xplay 6 warmer? Similar width?
Meizu pro 5 is not available anywhere and I’m not totally satisfied with the V20 being slightly cold/analytical in the vocal (although the detail and depth is impressive).
Am I forced to buy a high end DAP to achieve this sound? I hope not!
(BTW I don’t notice much if any of a difference between normal/aux/high impendance mode for my v20... other than loudness)
Xplay6 is slightly warmer and wider sounstage with more extended subbass and a little more euphonic vocal than V20. (I have rose mojito w/ brimar sxc cable and find it has good matching together.)
By the way, are you a cable believer? Did you try match your cable-swapable earbud with another aftermarket cable?
If you have chance to go to any canjam, try testing ibasso DX200 + AMP4/5, you will find a heaven of audio bliss and DAP will be your another men's toy in life.
Because nowadays, scope of audiophile smartphone is just LG, meizu and vivo that make me bored and need to find additional toys.
