650$. I think xplay 6 is the best smartphone but i don't see it on any market on my country.What is your budget by the way. Or you are on limitless budget?
Best Smartphone for audiophile Part II (Updated: Jan 2020)
- Thread starter artpiggo
- Tags
- smartphones
For all-in-one audio smartphone, I would recommend xplay6 if you can find a merchant who can import stuffs from china.
But if it is too difficult to find, I think finding DAP is much easier. You can visit Xuan Vu Shop in your city. Probably more convenient than carrying a DAC/AMP with USB cable.
Fiio X5 Gen 3 is a good starter. Other recommendation is Opus 1.
Any other smartphone? Xplay series is impossible for me . Opus 1 i don't see. What about fiio x7 mark ii?For all-in-one audio smartphone, I would recommend xplay6 if you can find a merchant who can import stuffs from china.
Other smartphone, please refer to my google excel table sheet.
Opus 1 is available on Xuan Vu website. It is a great warm sounding DAP with superb deep bass.
https://tainghe.com.vn/opus1.html
Fiio x7ii, I dont enjoy its vocal much. Recommend x5iii.
Thanks youOther smartphone, please refer to my google excel table sheet.
dragonball
- Oct 18, 2009
Where is your Google excel table?
Didn't you see the link in my first post here?
...only if you use it in balanced mode. honestly, fiio x5 iii doesn't sound better than a cheap shanling m1 when using the single ended jack. balanced output is a completely different story, though....Fiio X5 Gen 3 is a good starter. ...
Yes Absolutely.
bataskhayal7
- Oct 18, 2015
Hi,
Im interested to buy a Fiio K1 USB DAC for my on-the-go purposes considering my LG V10 is very poor on battery life. I carried two phones LG V10 and Nexus 6p. Audio on Nexus 6p are not that great so I was hoping that the Fiio K1 could somehow make it a little bit better so it could be the perfect backup for music listening.
However i mostly listens to music through Spotify extreme quality, does the Fiio K1 works with Spotify or only works for stock music player?
Thanks
Thanks
Hariz Nordin
Hi guys,
I'm getting the q1mk2 later this evening..
Anything to advise?
I'm using my Motorola moto g5 plus (sold off my oneplus 5) as my source, listening mainly to Spotify..
Sennheiser momentum 1.0 on ear as my phones..
Thx in advance
Anything to advise?
Thx in advance
Living legend of audiophile smartphone!
Wow.. is that a fresh peice..?
Nope, Just second hand.
Hariz Nordin
Just got my q1mk2..so happyHi guys,
Anything to advise?
Thx in advance
Total: 17 (members: 0, guests: 17)
