tienbasse
- Dec 5, 2011
400+ hours of JVC HA-FX850, with upgraded cable, bass is correct, extended and not too much at all, really nice to listen to. In my memory, 100+ hours is not enough for the beast. Cable is important for it.
I concur, you can control the HA-FX850 bass by changing the cable, which is easy due to the standard connectors.
Want more bass? Go for a large diameter pure copper cable.
Want less bass ? Go a cable with some silver. Warning: if you go pure silver, the effect will be dramatic, and you'll gain some extension in the treble. It is removing too much bass for my taste, though.
And burning of these HA-FX is long, very long indeed.
