BrucYSN
- Feb 11, 2011
I use the STAX in my sig for gaming and found them always enjoyable. What they don't do well is the very heavy explosions which will, I'll use the words, "break up". A perfect example is when the atomic bomb goes off in Call of Duty: Modern Warfare. They could not handle this where as the Denon D-7000's with the MiniMAX had no problem. The Denons with the Beta 22 in Dead Space 2 is just awesome. What I'm basically trying to say here is don't overlook a good dynamic setup for gaming bliss. The STAX are the best for hearing the slightest detail (try the Marine mission in Aliens vs Predator 2) and they will blow you away except for them certain, but not all, bass heavy stuff like rocket engines, explosions and big crashes. It is very annoying when the "break up" occurs and really takes the fun factor out of the game because you will expect it to happen... Don't know if the newer or better Stax headphones/amps will have this issue but in your case, since you are on a low budget, this will be a heads up for you so you won't be too disappointed. The open nature of Stax will surely bother other people in the house if used for gaming which is the major reason I also went with the closed Denon. My advice is to wait for a STAX setup for gaming until you have more money and spend as much as necessary for a kick ass gaming system. If for music... than a vintage STAX system will be well worth your effort to find & buy and I'm sure you'll be hooked on electrostatics for purchase in the future.
Break up? you mean the distortion? serious distortion usually casued by the source or amp i my experience, make sure you turn off the EQ
