cappuchino
Previously known as sub30
Am also waiting for the comparison. Do you have an estimate when your shipment will arrive?Ok, I will compare when I have the range coming from BGVP. Already have AET07 and 08.
Last checked , has not reach my local custom yet.Am also waiting for the comparison. Do you have an estimate when your shipment will arrive?
Yeah, those elliptical ear tips are way too small for their designations IMO. The large should be labeled a medium. I typically use the largest size ear tips, such as L Sednas and LL Final Es. The elliptical ear tips take some experimentation to figure out the optimum orientation for your ear canals, but once you get that part figured out, for me, they work amazingly well with certain IEMs that benefit from deeper insertion. They work great with the Mangird Tea, the LZ A7, and the Final E3000.Well, this morning I took delivery of the a 3-pair set of ADV EarTune Fidelity U tips, size L. Total bust for me. Zero seal, way too small (yes, I have large outer ear canal openings and are a bit recessed, so I need large tips to achieve seal).
Oh well, at least I got these with a discount code (would not have taken the plunge otherwise, tbh). Wasting $17.50 is better than wasting $25, hahahaha.
On to the next tips, I suppose. Thanks to a recommendation on another thread, I have some Tennmak "super strong" foam tips (cheap, on sale) coming to me from China.
Since coming back to the hobby, oh, about 5 months ago now, the best "new" tips (**for me**) remain the AZLA Sedna Earfit lights....by a huge margin. Only problem is the size L are just a wee bit too big, but the ML don't give me seal. My ears are such prima donnas, hahahaha.
Well, they look similar but not the same. How do they feel like? Just like stock tips or better? And I'm more curious on the A07 tips? How do they change the sound?
Just came,you be the judge![]()
Let you know when I tip roll them, its not the feel I'm looking forWell, they look similar but not the same. How do they feel like? Just like stock tips or better? And I'm more curious on the A07 tips? How do they change the sound?
What size are t400 foam tips usually? I would think that means 4mm but does it change with each maker?
Thanks very helpful.Tip, size listed to fit (actual bore I.D.)
T100 3.0+ mm (2.7mm)
T200 4.5+ mm (4.3mm)
T300 4.0+ mm (3.6mm)
T400 4.9+ mm (4.7mm)
M550/550S 5.5mm+ (5.3mm)
TS200 4.5mm+ (?)
TS400 4.9mm+ (4.7mm)
TS400 6.5mm+ (6.3mm)
TS200 were ordered recently so it'll be a few weeks until I get them. Probably 4.3mm I.D. like the T200.
Confusing though...why does t200bhave bigger diameter than t300.
I've just had the same problem. But I've had to pay full price plus custom fee's. Cost nearly £40 altogether. What a joke, managing to get a slight seal if I put in Symbio S form inserts but not ideal.Well, this morning I took delivery of the a 3-pair set of ADV EarTune Fidelity U tips, size L. Total bust for me. Zero seal, way too small (yes, I have large outer ear canal openings and are a bit recessed, so I need large tips to achieve seal).
