dasher5000
- Jan 24, 2013
So the AKG K550 is the best for me.
Okay, this is as clear as i can be. I want a headphone that has leather earpads that are very supple, a low impedance under 60, neutral sound, very large soundstage, closed back, all music gernes headphone that can also be used for movies and gamming.
My opinion is the AKG Q701. But it really depends on what you want a set of headphones to do. The Q701 really does play most genres very well. I find them to be best with electronic, jazz and classical. They are also very comfortable to wear for long periods of time. Tons of detail. Tightest bass I've ever heard as well. My favorite for the 200-300 dollar range.
Q701 seconded. Fantastic can! Needs an amp though to truly sound great. It's like $230 on Amazon. Pick up a pair, play pink noise through it for 80 hours while you work or w/e. plug it in, and you will not be disappointed. They have great soundstage, and feel very intimate. I'm personally waiting for my Little Dot MKiii to come to really bring these to the next level. Can't go wrong with the Q701.
Also, the K167/267 are fantastic. Great closed cans, feel pretty open actually, with great isolation. Definitely a great can for the price, at 199/299 respectively, Id say the K167 is a great bargain.
I'm A minor :/ . Oh well, I'm still solid with the K550
You might really hate the Q701, or the K240 MKii, or the K167, or the DT880, who knows? If you pick one, you can be sure you will be happy,as most cans recommended on these forums are generally (generally) a good price/performance ratio. So it's up to you to pick from the pool of headphones recommended to you, because if you pick one, you will be happy.
Hmm. There's optimism for you.
P.s. Im saving up for the akg550 or k551. Most likely the K550
