Hi There!
Thanks. I was more asking about whether I should consider a SS Amp to go with my Tube Amp.
Are the two pictures above, one stock and the other with the modifications you have recommended? I am reluctant to mess with my Crack as I am pretty inexperienced and would then not know what troubleshooting to undertake if it went wrong, or know what voltage checks or resistance checks to run before I powered it up. I can build things, I am reasonable with a soldering iron, but I lack the electronics knowledge beyond that. If I had an idiots guide I might be able to do it.
Did you not put a speedball into your one, you just did the mods you mentioned? Or does it have both?
I am running whatever tubes came with the unit. I am happy to consider changing the tubes, as I don't think much can go wrong there.
Yes the modified Crack has the speedball fitted the other pic is of a basic stock crack.
If your running stock tubes try something like the Svetlana Winged C 6H13 or Mullard 6080 would be a good place to start.
Ask for some recommendations for tubes on the Crack OTL thread
http://www.head-fi.org/t/476650/crack-bottlehead-otl/6825#post_11528117
