EliasGwinn
Member of the Trade: Velidoxi & Benchmark Media Systems
- Feb 26, 2007
Thats odd...does it happen while you're playing audio?
If I was to wager a guess, I would say that your power management is shutting down the USB ports.
How often does it happen?
Thanks,
Elias
Originally Posted by omegared /img/forum/go_quote.gif Hi Elias, I have some synchronization issue with my DAC1 USB to my HTPC. Every now and then, my HTPC is having trouble synchronizing with my DAC1 USB. On my DAC1, I can see the LED blinking for awhile and later the lights are off. I need to unplug and replug in the USB cable in order to make it work again. Is there anything I missed here? Any XP settings needed to be done? Does anyone have the same problem? |
Thanks,
Elias
