Nov 12, 2008 at 3:34 PM Post #2,056 of 3,058
Originally Posted by EliasGwinn /img/forum/go_quote.gif
Tell me more about what you are trying to do.
I want to connect it both to a heaphones amp (need fixed output ones) and at the same time connect it to a streo power amp
So, missing two outputs
Nov 12, 2008 at 4:25 PM Post #2,057 of 3,058
Two possible solutions:
1. Use the RCA outputs in 'Calibrated' (fixed) mode to feed the headphone amp, and use the HPA2 (headphone output) with a phono-to-RCA cable to feed the amplifier. The HPA2 may be a bit hot, so if you have the DAC1 USB / PRE, you would want to lower the gain range of the HPA2 as much as possible.
2. Use the HPA2 for your headphones.
Thanks,
Elias
Nov 12, 2008 at 4:33 PM Post #2,059 of 3,058
Why not adding RCA out to the unit?
I mean, it will be nice to have both variable and not, will even make it easier to use and so on
Maybe on the DAC2. Stay tuned!
Nov 12, 2008 at 4:55 PM Post #2,061 of 3,058
Originally Posted by tps /img/forum/go_quote.gif
Well, I ordered a DAC1 PRE yesterday to use with Magnepan MMG speakers and Outlaw 2200 amps.
good choice on the maggies. I started with that pair and I love them. a bit inefficient but not a huge problem given their good flat sound (heh)
I rarely run into folks who have the maggies and it seems that 'boxy tower' speakers are so much the rage these days (sigh).
Nov 12, 2008 at 8:17 PM Post #2,062 of 3,058
I have a brand new DAC1 USB.
My unit behaves a little strange with standby in USB mode. If I pull out the USB cable from the active Benchmark standby mode is never engaged. If I shutdown my computer with the usb cable attached standby mode is working.
The only way to make standby work is to reset the unit or start my computer and thereafter shut it down.
I´m a little puzzled here because I mailed Benchmark support and got the answer that it´s normal that both LED´s is active even in standby.
Nov 12, 2008 at 9:05 PM Post #2,063 of 3,058
Hello Jotos,
What they meant by "normal" is that this happens with a lot of computers. The DAC1's USB input is always locked to the computer in slave mode. Certain computers lock to the DAC1 differently then others. The DAC1's USB input has a "handshake" with the computer. For the USB input to go into standby, certain computers must 'sign off'. If the USB cable is removed from the DAC1 without those computers signing off, the DAC1 won't know that it is disconnected, and it will stay in 'active' mode.
Thanks,
Elias
Nov 12, 2008 at 9:30 PM Post #2,064 of 3,058
Hello Jotos,
Thanks,
Elias
Ahh. Thanks for the explanation. Now I can focus on listening
Update: I just moved my DAC1 from my Thinkpad (Dac1 standby when shut down) to my HTPC. With my HTPC DAC1 never goes to standby, not even when HTPC is shut down. Are there PC:s that lacks the ability to force standby?
Nov 13, 2008 at 5:48 AM Post #2,065 of 3,058
Originally Posted by Quaddy /img/forum/go_quote.gif
MIT audio state burn in is required for their cables
my MIT cables included a booklet detailing the required burn in for their IC's
they state the 2/2 rule;
75% of performance in two days
100% in two weeks
i am not arguing about whether you believe it or not, i am just providing facts that a cable manufacturer quoted burn in as you said you hadnt seen any manufacturer say
I know MIT cables have "networks", but those boxes have ICs in them?!? What?! Don't ICs require continuous voltage to power them? How the heck could you do that in an interconnect or speaker cable, where the whole idea is to transmit a signal by varying the voltage. Do the cables require an external power source in addition to the signal?
Nov 13, 2008 at 11:33 AM Post #2,066 of 3,058
Elias, is such an updated product release imminent? Did I buy a DAC1 PRE right before the "next greatest" thing comes out?
Nov 13, 2008 at 2:10 PM Post #2,067 of 3,058
That's right. Some computers simply don't 'sign-off' on their USB port.
Thanks,
Elias
Nov 13, 2008 at 2:14 PM Post #2,068 of 3,058
No, it was merely a way of telling 'HeadLover' that we will take his suggestions into account when we develop new products.
Thanks,
Elias
Nov 13, 2008 at 6:24 PM Post #2,069 of 3,058
Thanks,
Elias
That’s a shame I will have to cross it of my Xmas list
Nov 13, 2008 at 6:40 PM Post #2,070 of 3,058
I've had the DAC1 PRE for about a week now. An EXCELLENT sounding piece of equipment. The MMGs are ruthlessly revealing speakers, and the DAC1 also seems to be very revealing. On a good recording, such as a Linn or Classic Records 24/96 file, the DAC1 / 2200 / MMG combo blows me away. On average recordings, well, it sounds average, but that's the way it was recorded...
