EliasGwinn
Member of the Trade: Velidoxi & Benchmark Media Systems
- Feb 26, 2007
Scrith,
Regarding the -30 dB attenuation setting, the sound should not change if the final output level is the same. The attenuators are purely passive, just before the output. The only change is the output impedance (lower output impedance is better), but the -30 dB is the lowest output impedance setting (43 ohms) of them all. So, I don't know why you are hearing something going missing when you go from -20 to -30 dB.
The problem with this implementation is that it requires the operating system to re-sample the audio to the clock of the converter. This is a problem because the re-sampling algorithm that Windows and Mac uses is absolute garbage.
Even if the master clock from the outboard DAC tells the computer to play at the same sample rate (44.1k for a CD, for example), the computer still must re-sample the data to be synchronized to the DAC's master clock.
So, it is true that the audio is transferred using the DAC's clock, but it is at a very costly tradeoff. For outboard DAC's that struggle with jitter, it may be a worthwhile tradeoff.
This USB mode (asynchronous) is not new. When we designed our USB interface, we made the decision to not use this mode. This is because, as I mentioned, it requires the computer to re-sample the data. Therefore, with our method, the computer can simply pass the data to the DAC1 bit-transparently.
Is there a lot of jitter on the data coming from the computer using our solution? There sure is! But, luckily, the DAC1 can handle any amount of jitter with no loss in sonic quality. In fact, the performance of the DAC1 using the USB from a computer is equivalent to that of the DAC1 using a high-end transport with a high-quality 75-ohm coaxial cable.
The DAC1's USB solution is the best of both worlds...it eliminates the horrible OS re-sampling and it is immune to the computer's jitter!
Thanks,
Elias
Originally Posted by Scrith /img/forum/go_quote.gif Well-known high-end audio manufacturer Ayre will soon be releasing a DAC supporting USB input that supports an asynchronous USB mode (via USB firmware licensed from Wavelength Audio, I believe). This asynchronous USB mode allows clock(s) on the DAC to determine the transfer rate of data from the computer, rather than relying on the computer's (inaccurate and jitter-prone) clock(s) to determine the rate at which data is received (and thereby necessitating resampling on the DAC side to overcome this poor timing). This new firmware is particularly interesting because it works with the existing Windows and Mac USB drivers. |
Originally Posted by Scrith /img/forum/go_quote.gif I mentioned this a few months ago and haven't heard much about it since then, so I'm wondering if there is any update. Does Benchmark have any plans for a new DAC (or an update to the firmware for existing DAC(s)) that supports this new variation on USB audio data transfer? This evolutionary step seems very important, because it finally eliminates all computer clock related jitter from the source (without providing a band-aid solution like resampling or intermediate buffering). |
Thanks,
Elias
