tourmaline
- Nov 10, 2003
yes there is still energy after shutting off the amp. I measured the power over 24 hours the moment you shut it down, it takes about 24 hours to go to almost zero voltage...the 2 diodes however block any signal comming in above a certain value...so, no problem there. More components in the signal path might mean devaluation of the signal.
Originally Posted by Pricklely Peete /img/forum/go_quote.gif I wonder if a little bleed circuit couldn't be put together for the Bada that won't harm the signal during use ?.....Use a high quality DPDT (or SPST) 250V 5A toggle (on off on) connected to the filter cap reserves on one pole and current hungry super bright LEDs on the other pole. Have the LED out the signal path in one position for the operate/listening mode and in the that path and on for draining the caps of their current when the unit is shut down and you intend to swap tubes...when the LED has used up all the stored energy it will fade and you can now swap tubes without blowing another mosfet. Maybe a an additional period of say 1 hour after that LED has faded would be better ? Just a guess really. Maybe I'm wrong about this but I have observed my Odyssey SS amp using the LEDs after power down to use up this stored energy, sometimes it takes as long as 45 seconds for the LEDs to fade out ( 120K of filtering). Is there still stored energy in the caps after the LEDs fade ? Maybe so, I need to measure it with a DMM to know for sure. Sorry about the slight OT post everyone. Just thought the idea may help the situation. Peete. |
