Ronion
- May 17, 2013
Shouldn’t the shorter ones make the canal resonance go up in frequency?
I thought it was otherwise ? But im no expertShouldn’t the shorter ones make the canal resonance go up in frequency?
http://rinchoi.blogspot.com/2010/05/how-deep-do-you-insert-you-er4.htmlI thought it was otherwise ? But im no expert
The black short sedna has stiffer material vs the light short. From my experience it add a bit more bass than the lightHi everyone, i am going to order Azla tips but what is difference between Azla Short (regular short) and Light Short in term of sound?
The short sedna actially function the same as other regular tips. The non short sedna has a tube like effect, speaking from my experienceShouldn’t the shorter ones make the canal resonance go up in frequency?
Whether it's narrow bore or wide bore, it doesn't really matter tbh & the deeper you insert, the peak will shift to higher frequency. The measurement crin did is setting the resonance peak at 8k but in reality, we tend to have it at 9k-10k. It will not make it go higherso basically it looks like bigger bore and deeper insertion makes the resonance go higher And with a less intense peak.
Azlas come pretty large. Check their size chart...and measure your go-to tips for comparison.Thinking of opting for a long nozzle, should I go M or MS if I normally go M? Never had Azlas before. What's the consensus on regular vs light in terms of sound and feel?
