hi everyone...newbie to the thread
...i'm in the market for some waterproof iems for they
gym, esp those that have a good seal.
aside from this model, there is also the trinity atlas
which has the extra flexibility of different filters.
similar price points....has anyone compared them
for SQ, build quality and such?
thanks
I've owned both previously, and put reviews up in the Head Gear section (check out the reviews section on my profile). Atlas is good, with a bassier and more aggressive signature than the Rockets, depending on what filters you choose. Both are good choices - Atlas comes with 3 different cables, one of which is only 0.6m so designed to work with a phone or DAP in an arm holder. Atlas has a shallower fit, but if you use the included foams or have smaller ears it should seal well enough. Ther is also an MMCX Bluetooth cable coming out for the Trinity line in the next 2 months if that matters.
Bottom line, both are very good choices - I prefer the sound from the Rockets fir all round listening but the Atlas works well in the gym and is more adaptable with the choice of filters and cables in my opinion.
If you do go down the Atlas route, if you buy direct from Trinity don't forget to use the Headfi members discount code for 20% off!
