incredulousity
What about the amp do you find wanting, that you “upgrade” so fast to Nirvana?
Congratulations, this is a spectactular Upgrade ! With a Price more as double to the HA-2SF it is basicaly affordable. I am not sure if the Nirvana is 2.5 Times better than the HA-2SF (if you dont need more Power). However, the Nirvana is one of the first Generation Amps in the Auris Lineup. I would`nt be supprised If they launch e successor this year.Other than being a little nuts, unable to roll the driver tubes was the first thing that bothered me but I'm new to the game also. I honestly felt limited with a drive tube that has two choices only manufactured by JJ. Gold and standard. What you see if what you get. It honestly really stuck in my craw and I'm probably over thinking it. The el34 if I read correctly is a popular guitar amp tube, not that it means anything.
Here's the reason why I went with Nirvana versus ampsandsound besides the above comment about tubes, availability was key and I already had 1800 credit with moon audio. (airing my laundry here). I was impressed with Auris and yes, it's not well k canown, so this has been a gamble. I could have ordered from ampsandsound and waited five weeks, which I'm horrible at and I've never heard an ampsandsound amp. So I decided to put the 1800 toward the Nirvana and try to get as much as I could from the HA-2SF (which I really didn't get as much as I could have) and coveprir the difference. Hopefully the grail end game amp?...
Bonus with the Nirvana is the diverse impedance selection (five options versus the three with the HA-2SF) (and all my headphones are 300 ohm right now) and one transformer per channel versus the single transformer on the HA-2SF. The HA-2SF is 20lbs and the Nirvana is 25lbs (this is not a bonus just an observation). You do hear a difference between the three settings on the HA-2SF but I did end of staying with the mid setting as for some reason I think I read where you match the resistance, you get less distortion, I could be wrong.
What would have been going would be having the two side by side but unfortunately, I sent it out the door this morning. Will I really hear much difference between the two? probably not. I'll have an idea tonight while the HA-2SF is semi fresh in the mind.
Hi RoikyouIs the 3k plus worth the extra flexibility, probably not. I've had it since last night and have yet to listen as I'm at work (and surfing the forums). Tonight I'll have a better idea. I think it's kind of I have an opportunity to see what's on the other side and I'll see that tonight. I've tried a 3k ZMF and a 1k ZMF, honestly, I really like the 1k ZMF. I've tried the Focal Clear and mg, still prefer Arya > LCD-X > ZMF. Unfortunately, I've done more research after the fact than anything, so far, I like what the Nirvana presents. I don't think there is any headphone out there (and this is just an assumption and from what I've read and heard) that there is any headphone that either the HA-2SF or Nirvana can't drive. I've read reviews where the Nirvana paired with the Susvara and they performed very well together. Am I going to pay 6k for a headphone, no. That one will stay out of my price range. The Nirvana was a reach, the end of what I was willing to spend. I'm running it with the bifrost2 and I might eventually update it. I'm down to the ZMF Aeolus and ZMF Eikon now. I think I'm close to done. (famous last words)
