xxx1313
Hello all - I need your help with the following. I have an Auralic Gemini and an AK240 with lots of DSD files that I mainly use as transport. I would like to feed the Gemini with the DSD files on the AK. I can't find a conclusive answer whether this is possible and which of the three ports on the Gemini (http://www.auralic.com/gemini/#Connections) I should use. Also, what cable would I need to connect the AK240 to my Gemini? Pretty new around here, so any help much appreciated. Will post this in the AK240 forum too. Thanks, Pieter
Toslink (with mini Toslink adapter at the AK240)! The unbalanced output of the AK240 is also a mini Toslink output.
If you have the money left, try a good quartz (not plastic) toslink cable like QED Reference Optical Quartz. You will hear the difference! I use it between AK240 and Auralic Vega.
