This is endgame for this DAC.
The Sparkos SS2590 pro dual is the pinnacle of what the DAC can produce. Better than the SS3602, Better than the Burson V6 Vivid. I was thoroughly thrilled. I have been putting it through the paces and listening to it daily since it was received.
Read up on this op-amp and find out why it is the truly the best discrete op-amp you can buy. "These discrete audio op amps have been used at RCA studios in their Mic Preamps, and by other manufacturers such as Nord Acoustics and Apollon Audio in their Hypex based Class D Amplifiers".
Everything is just more. Faster transients, faster decay, lower noise floor. Airy, crisp, punchy. Bass with layers and depth. Deep soundstage. Truly taking a really decent entry level DAC and putting it on par with more expensive units. I couldn't be more pleased.
The inclusion of the Aune XP2 and the 9V supercapacitors suggested by @Ghoostknight, along with my custom made Teflon Silver-Plated Star Quad JSSG360 cables with Oyaide connectors truly help this X8 XVIII shine as well....
What's with the pics?
With a bit of 2 sided gorilla tape, you can attach these feet and raise up the DAC sufficiently without it looking silly. I could probably do a better job trimming the tape but I never see it exposed from my vantage point. It could still be neater though.
The project box, with some light modifications can be used to snuggly hold the SS2590 dual pro inside. Using some sandpaper, I was able to carefully sand the edges of the box itself so it was the exact height of the feet with the tape. Using a rotary tool I was able to remove some material from the inside of the box to allow the op-amp to perfectly friction fit. The op-amp was seated to one side of the box so that the box itself acts like the rear right foot of the X8
Using a scrap piece of one of those fake leather desk mats, I was able make sure that in nesting the opamp, it was still able to fully engage the socket under the Aune X8. The scrap is between the opamp and the box.
Based on the discussions I had with Andrew at Sparkos, the little box was vented. I used a scratch awl and a manual boring tool to make 3 precision vent holes on each end of the project box.
The pics you see of the box on the bottom with the X8 upside down were the first run at making this little protective cover. I ruined the first version while using the rotary tool to make the vent holes. The second version is where I adjusted the placement of the op-amp to one side of the box and used the hand tool to carefully make the holes you see. It turned out much better.
The op-amp is quite large and I felt it could possibly wiggle it self out. This would be detrimental and possibly destroy the unit and the op-amp. I also, as you see in the pics have a problem with pollen. So I decided to do the best I could to protect the op-amp from dust, debris, pollen, moisture, etc. The box itself keeps the op-amp snug in the socket. And being that it is the same height, I can have the unit upright on my table.
I agree somewhat with
@Ichos in that the op-amp system would be "better" for the end user if it we're on top.
All in all... This, for me... Is endgame. This is a great entry level DAC that you can truly take to new heights. Punching way above it's pricepoint, I dare say, based on listening to a few of the more expensive units out there in much more expensive systems, that we have a shot at performance that is nearly on par with $1500 to $2000 units. For under $700 total... I'd say I did OK here.
I'd like to thank again
@Ichos &
@Ghoostknight , as well as everyone else who turned me on to this unit.
Time to listen to tunes...
