My apologies... I kind of forgot you moved on to that Sony gear.
So for the integrity of the thread, I will say... The supplied Meanwell SMPS is decent and it does a fine job. The Aune XP2 does take it up a notch a bit. I believe the shielding in the enclosure has a lot to do with it.
Sometimes linear supplies can produce a lot of EMI that a DAC can pick up. Especially with the short, short cables Aune supplies. I think a nice silver plated star Quad JSSG360 DC cable with a 1m to 1.5m length might be helpful. Allowing you to keep the XP2 further away. Just in case we are defeating the purpose of the XP2 by having it too close to the X8 XVIII.
Introducing the new supply and the cap bank - for me it's tough to say... I have made so many little tweaks here and there over time to the system as a whole that were getting near the end really. So close in fact, that the little things I do now are subtle but still somewhat noticeable. But I am definitely approaching the land of negligible.
So, as you know, I got the linear supply last week and these things tend to make our noise floor drop and we get some real black blacks. At least this is the goal.
My cheap little bedside power house is kind of the stuff of legend now(not here per se) and adding these two new items definitely could be appreciated.
A lower noise floor can have a profound effect on the amount of bass you hear. Not more of any one thing, but details come forward. Like the pluck and ripple of an upright bass and the string wobble and buzz. Low fluttery horns. Tightly tuned low end Tom Tom's. Breathy low vocals like Adele or D. Krall. Dubstep synths.
The most changes I feel.are taking place in the mids where all the mud can be. So many overlapping frequencies that some speakers and cans can't keep up the transients and decays like they should.
I wish I had the new Mofi Sourcepoint 10 speakers or some more capable audiophile headphones.
The KEF LS50 Meta's and SVS SB-1000 pro are handline things well. But for me, a 5 inch driver can only do so much. Tomorrow I'll be putting on the DT-1990's and giving a listen. Gotta keep things HEAD-FI
The highs... This is a tough nut to crack. As we age and we lose our upper freq's, sometimes noise in our gear in this range helps because of carrier frequencies. I have super tweeters that can do 10khz to 40khz and even though you can't hear those upper numbers... You can detect them when mixed with an array of carrier frequencies. Things become airy... But we don't want the wrong type of sibilance. So while I enjoy analytical gear and clean sound, the benefit of this particular linear supply helps with clearing the empty space. The tink of the cymbals. Stick cracks on the sides of drums. Wild synth crescendos.
Now when I added the super capacitor bank... This was just more. It seems that everything that the SparkosLabs SS3602 Dual Discrete Op Amp did, the natural smooth sound that was somewhat lost with the Burson V6 Vivid is now somewhat back... Again.. Tough to say... To quantify with words. And I truly would need some REAL A/B tests... But things sound the best they can I think now. Unless I snap up. A Burson Soloist
But where the biggest difference is I think is that I notice that with very low source volumes. When a lot of amps, systems as a whole... Gear as inexpensive as mine technically is... You can actually lose details and have balance issues the lower the volume is. Firstly, So Glad that none of my gear does that... .
I'm impressed with all the detail being in play during near field at such low volumes. I will be able to listen a bit more intently tomorrow and I'll be sure to use the headphones.
The only thing left for the Aune now is the custom power cables. I need angled plugs on one end and straight plugs on the other to properly incorporate the gear.
So to
@Ghoostknight , A hearty thanks for turning me on to the bank. The mod was an easy fix with a wedge of closed cell foam. However, I am a tinkerer and I will look into better caps. I did take it apart when it arrived to address the rattle. I will probably just use the best caps I can get at the same values though. This little thing is a winner.
Perhaps a new thread on these supercapacitors units is warranted. Keeping this place free for the Aune X8 XVIII crowd to have some clear guidance without too much fluff.
