CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Nice! Any update about that amperex tube? Just even briefly, do you like it?
Anyhow, first impressions are: very detailed, powerful, spacious, clean, not "tubey" at all
1- Did you notice clear changes after "break in"?
What would a good tube to try? I listen mostly to acustic music: jazz, brazilian and the like
everything you can throw at it. I truly feel like I don't deserve this tube sometimes
Don't forget there's other tubes than Amperex ones ... Many brands made e188CC/7308 such as philips , Mullard , Dario etc which are easier to find and far less expensive. My last NOS from 70s e188CC from LaRadiotechnique costed me 26€ .
Russian Voshkod 6N23p is often considered equivalent to E188CC/7308 and costs around 30€ here or there.
dcfis, what do you mean by it? For foobar there is this thread that you should propably read: http://rockgrotto.proboards.com/thread/7039/basic-foobar-configuration-1st-posts
Personally I don´t bother messing with foobar, traditional classic winamp + ASIO and KS plugin. Which plugin to use is up to you. First try KSO plugin: http://www.thefreewindows.com/2605/bypass-the-windows-audio-mixer-with-the-winamp-kernel-streaming-plugin/ and then ASIO: http://www.thefreewindows.com/2513/asio-plugins-for-winamp/ . For me ASIO plugin + ASIO drivers worked best because with KSO it didn`t seem to play in 24-bit (even when 24-bit box is disabled in winamp), KS status showed 16-bit while 24-bit file playing. But well, most FLAC and other lossless formats are in 16 bit per sample anyway, so it shouldn`t bother most ppl. KSO is a lot easier when you have no 24-bit music files. More info about KSO @ Winamp: http://www.hifi-advice.com/Winamp5-kernel-streaming-info.html (don`t set input/output buffers too low or you might get jitter and crackly sound). Also note that with KSO, depending on if you check 24-bit box or not, the output sound is slightly different.
e: These are my settings:
wasapi should be the preferred and good-enough method, since ASIO is not needed as it is plug and play
Thanks for the quick answers, Folks. The amount and depth of your info is awesome.
Yes, I have the 6922EH. It came with the T1. I'll take the time to read through the tube options and start rolling...
Regarding how I play, I use foobar with WASAPI output.
@CoiL: Please post a picture of your tube collection in the wood box. Sounds fascinating.
