I guess its about choices. My way costs like $25 for a supply that will last quite a while, no mess and takes 3 minutes. Cleanup is put the cap back on.
Don`t take following personally but I call it consumerism with lots of brain-lazyness. People nowdays do not think about using what they already have. They are like robots pre-coded only to buy buy buy. Although, I think in general typical educational system there is lot of BS that is forced into your head and do not actually need in real life, there is still much you could use to keep your money and
use/re-use that little you already have. In this case basic school chemistry (btw I sucked at chemistry lol). It isn`t hard to open kitchen cupboard and take 2 things, mix them together and put the tube with re-using your junk-paper/carton in it. Honestly, my method took me too only few minutes (not counting ~30min while tubes soak, I did other things meanwhile). Think, move and use your brain and skills you`ve been given! Don`t just waste it. Heck, you could teach some useful things to your kids maybe? Also you could clean your stuff this way, keep that 25$, go out on street and give it to someone who really needs this money (or maybe to some local charity)! Now, think about it - you`ve
used your "useless"
skills,
teached something to someone,
re-used your junk and
helped someone who is in lot worse situation in life that you are - isn`t it all positive? By buying deoxit - you have given away your money to corporative system, fed chemical production, polluted nature by it, done no good to anyone, wasted time to shopping,teached nothing to nobody - isn`t it all negative?
Yes, it`s about choices and people should really step away from their comfort-lazy-zone and start to think further than their noses.
Just my little thoughts in this morning
Edit:
Btw, I looked up some information about those stock main power supply caps and I couldn`t find that size (physical) RJB type Elna capacitor in Elna 2013 catalog.
It could just be cap from older catalog/production but maybe fake one too? Anyway compared elna cap specs to this Panasonic FR series (new) cap that I ordered and latter has better specs. Probably won`t make difference but I feel lot better knowing my Aune T1 has quality caps in it
Will take pictures when I open my Aune T1 again and make a short "guide" how to take Aune T1 apart.
